My first Skyline was a 4 door R33 GTS and I purchased a Cusco oval type strut tower for the front. It was the only suspension/body modification and it was night and day in handling. My R33 GTST has both front and rear round type Cusco strut tower bars and I am happy with them, though it would be nice to have exotic titanium strut tower bars :woot:
I think the underbody is robust enough to not need bracing, but then some cars, such as the new Subaru WRXs are known to have weak underbody bracing. But then I don't have aftermarket underbody bracing so I cannot say about how effective they are, I might get a set if someone says they are worth it.
For suppliers, maybe check Nengun or Perfectrun.
Thanks. I'm not too sure on the stiffness of the R33. I'm quite suspect on it. The R34 was apparently 100% stiffer or some such, well that was the blurb when they released them.
I think I at least need the strut brace at the front. Wondering if an under-engine brace exists?
underbody brace wise the only one i know of is the one that braces between the caster rod brackets
difference.. yes very little and not as much as a strut brace
i remember reading the r34 website on the old nissan japan site, it has a reinforced C pillar, they also mentioned that the r34 GTT chassis brace design was based on the R33 GTR, and R34 GTR is stiffer again
its true that R34 GTT and S15 do feel stiffer than R33, especially on driveways
again R33 is so big inside so naturally it won't be as stiff as an R34
S15 and R34 GTR have all sorts of funny braces from factory like the spare wheel well brace, transmission tunnel brace and rear subframe brace, sometimes it really makes you wonder if they really do anything
never really checked out the GTT so i dont know what braces they've got
The tower bracing will definitely stiffen things up.
There are also these, there is a rear under brace going around as well.
http://www.justjap.com/store/product.php?productid=16577&cat=393&page=1
http://www.justjap.com/store/product.php?productid=16583&cat=393&page=1
The R33 GTR has a lot more bracing through out it than the R33 GTST.
In the boot/backseat (not talking about the rear brace that is factory on S2 GTST's) and underbody from memory.
I'll try to find pics.
EDIT: No luck finding pics of the damn things i'm talking about.
I've often thought about welding some additional support to the stock sheet metal link between the strut towers and the firewall. I would think making these 2 sections wider and thicker would help a lot.
No that is NOT my strut brace - I wish it was though !!!
Edited by simpletool
yeah i looked into all of this fairly recently, most places set not to bother, i ended up replacing the suspension bushes through out and that made quite a difference even though the factory bushes were still in a reasonable condition!
not sure if thats much help, but no point spending hundreds on products that do very little!
my 2C
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
