Heaps of stuff to clear - all cheap as.
txt me only on - 0422 780 627 ....i wont be on here regularly to check my inbox.
Turbosmart wind up Boost Controller - good working condition - $60
Wind up Boost Controller (unknown brand) - good working condition - $40
S13 Front Seat belts - good working condition - $20
R34 Short Shifter Kit - Reduces height and throw - good working condition - SOLD
(bad point - allows gear box noise to come thru a little)
Blitz Boost Gauge - good working condition - $50
R34 GTT Standard ECU - designed for auto, worked fine on my manual. - $50
R34 GTT Standard front bar Indicators in nismo box - good working condition - $25
R34 GTT Front Wheel bearings - Brand new never fitted - $50
Fire Extinguisher (handheld) - perfect for track car - good working condition - $40
Alpine 6CD in dash stacker (double din) - japanese market sterio - good working condition - $30
(no wiring loom)
Sony CD player single din with brand new wiring loom - good working condition - $40
S15 Gear boot surround - one small chip in paint on bottom - otherwise great condition - $25
S15 Factory leather gear boot - 2 tears in leather, otherwise good. - $10
Nissan power steering rack rubber boots - for steering arms - brand new never fitted - $25
2off K&N air filter cleaning kits - both used once , nearly brand new. - $30ea
R34 GTT factory standard side indicators in nismo box - good working condition - $20
S15 right hand rear aftermarket tinted tail light - one off only, left side broke in accident - not LED - $25
HKS super sequencial Blow Off Valve - Brand new never fitted with all required parts - $175
R34 GTT Factory standard top camber arms - good working condition - $20
R34 GTT Factory standard front dumb pipe - good working condition - $20
R34 GTT/GTR Nismo rear coilovers only - height and damper adjustable - $100
one has leak and is making noise - bargain for repair
R34 GTT Factory Standard rear suspension - good working condition - $40
R34 CAT - been bored thru - good for stealth road car - $20
2off 19" tyres 235/35/19 sunway brand - bad camber wear - $40 for both
good for drifting
S13 Front Seats - excellent condition for age - no rips or tears - $50 for both
No stupid offers - txt only on 0422 780 627
Local pickup in doncaster - or pay xtra and i'll post.
Alex
  • 1 month later...
  • 3 weeks later...
Re Nissan power steering rack rubber boots - for steering arms - brand new never fitted - $25
Original Nissan parts or aftermarket?
_____________
Re Blitz Boost Gauge - good working condition - $50
Does the light work?
Les . . .
_____________
Les . . .
If this Les guy is a brand snob I'll take the rack boots for $30.
  • 3 weeks later...
  • 5 months later...
    • Holy hell! That is absolutely stunning! Great work!!!
