  • Replies 224
Jin - Looks like GC and southside are meeting at springwood crazy clarks, I though maybe the BP's would be easier for GC people but no one has replied to my "where is easiest" post so springwood crazy clarks at 7:30pm for departure at 8pm sharp, see ya there!
I will be at Milton Maccas as long as the weather is good.
Get a Uniden and only use duracell batteries if you don't have rechargeables. I use these thing all day every day at work and easily get one month of use out of the batteries. Use only duracell though, tried ALL the rest and nothing else comes close. Might be more expensive to start with but ends up cheaper in the long run, or go rechargeables, although I find them a little unreliable.
at Milton Maccas @ 7.30pm, so far we have got:
1) me
2) yoparata aka aaron
3) Charly aka james
4) yamutha33 aka warwick
5) Nismogirl aka Erin (only if... )
6) Jlnewton (only if dry)
anyone else?
my CB radio is on its way from ebay :D
I'll bring my brick :D even though I'll probably not need it, as hopefully either be hitchin with Nex or strutto, but then might hop in with someone without a radio :D learn new ppl cause just like mindflux I only reckognise like 3 or 4 people out of the bunch.
Hey Glenn, you wont be able to miss me, instead of name tags I got a shirt with SKA pasted across the front, will that do? :)
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
