ok let me first say, that this is typically what happens to me
i changed my spark plugs today, with BCPRE ones, and i used to have BK.. somethings... and the new ones are longer by a few mm, i dont know why its relevant but id like to say every detail
i changed them over no dramas, turned the car on and i have what seems to be a lifter ticking, and i have no idea why its doing this now....
i know this is a near impossible question, but any ideas WHY?!
Spark plugs are most likely wrong, the contacts aren't firing properly.
change the plugs again trial & error, it may even be that the plugs aren't
positioned correctly your engine's probably running on 5 cylinders...
engine runs smoothly, exact same as before, i put the old plugs back in straight after, and was still ticking.
when you change your plugs, it's a good idea to use a compressor or a vaccum to blow/suck out the dirt in the valley before you pull each plug out, so dirt and crap doesnt fall into the cylinder.
anyway, i doubt that would cause ticking, unless it was a big chunky piece of something that fell in.
The fact that nobody has commented on that worries me.
I know on SR's there are issues with particular spark plugs being slightly too long, and will hit things internally... I wouldn't be surprised if this is the case on RB's too.
Have you considered swapping your old plugs back in and seeing if the noise goes away? If it does, you've pretty much isolated the noise to those spark plugs.
He said he did try the old ones again, and the ticking was still there, but now has gone away.
Could it be possible that you simply left the car sitting, off, for a decent amount of time such that a decent amount of oil had drained to the bottom, causing noisy lifters?
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
