Hi All,
I posted a similar topic to this ages ago and the replies I got back were saying it could be the uni joints or the diff (maybe a bearing), both of which the guys at Autoworx (WA - where I bought the car) said were fine.
Now I have isolated it to fifth gear, in that for the same speed (say 110kph) it doesn't do it in 4th.
Basically getting a fair bit of what I'd call a rumble (not so much vibration because I dont really feel it in the steering) that comes on quite noticeably at 110kph, and is non-existent at like 107kph. Higher speeds it is there but it seems to be most noticeable around the 110-120kph range, and is mostly noticeable when I ease off the accelerator. My guess is that its something to do with the particular revs it is doing at 110kph (pretty much dead on 3000).
Car is completely stock (S2 R33 Gtst 1997) and has done 80000ks. Just wondering if it is something to look into. Seems to be getting worse, but very slowly.
Any suggestions?
  • 3 weeks later...
Does it do it at those revs in 1st,2nd and 3rd also? Have you had the gearbox out lately?
Hey sorry for the late reply. Nah doesnt seem to do it in any other gear - well, not noticeably anyway. And no the gearbox hasnt been out since I've owned it (about 14 months). Hmm.... Autoworx are looking at it now.
  • 3 weeks later...
Hey mate i have a similar issue in my 32 GTR, but it does it in 4th gear also. It sounds a lot like if the exhaust was vibrating on the chassis, but its not. At this stage im lead to believe it is a bearing problem from within the gearbox. If i load up the box by accelerating or holding a constant speed the noise is almost non existent, as soon as i let off the throttle the noise appears. I have done a lot of searching myself and my next move is to remove the gearbox, get it inspected and parts replaced as necessary.
cheers
  • 4 weeks later...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
