Hey people.
Well I’m off to study full time this year so need to sell the car and get something more practical. I’ve had my car for a couple of years now and loved owning it every day! Take a look at the pics and judge for yourself. Not to many cars getting around on 18x9.5+10s all round every day, these are my favorite part of my car!
The car needs a new windscreen + castor bushes for a RWC, I can do these if the car sells for the asking price, and otherwise u can get it done.
Item Summary: 1993 Nissan Skyline 4 door sedan
Condition: Used
Kilometers: 145k
Registration: September
Asking Price: $7900
Delivery Methods: Pick Up
Contact Info: call Aaron on 0411797868
ENGINE:
• RB25DET
• 5 Speed Manual
• Nismo Heavy Duty Clutch
• 3" Ganadore Exhaust (street legal)
• Aluminum 100mm radiator
• Standard Turbo
• Standard Manifold
• Cooling Pro Intercooler Kit and piping
• New Spark Plugs
BODY:
• Factory gun metal grey
• M-spec bumper
• Rolled rear guards
WHEELS/SUSPENSION:
• 18x9.5+35 G-max Energy rims all round
• +25mm bolt on spacers all round giving the car a +10 stance
• Pirelli P1 Semi slicks (fitted 4 months ago, still good)
• Bilstien Shocks, super low king springs (still at legal height)
INTERIOR:
• Pioneer head unit, Pioneer splits, Amp + Boot mounted sub (see pics)
• Blitz turbo timer
• Stewart Warner boost gauge
• Standard interior
Sorry no interior pics as yet, I will upload some soon
SPARE PARTS
• I have a set of fiberglass side skirts (unpainted) I can have them painted for $200
• 4 Standard rims + tyres (tyres are un-roadworthy)
• New boot with led tail light (non spoiler boot)
There are a few small dents in the bonnet, roof, boot and one near the filler cap. The dents were caused last year during the hail storm. I have a replacement boot with tail light (needs painting. I can take pics on request if required
SORRY THE REST OF THE PICS WONT UPLOAD, ILL TRY AGAIN LATER
https://www.sau.com.au/forums/topic/353447-r33-sedan-4-door-rb25det/
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
