Hey people.
Well I’m off to study full time this year so need to sell the car and get something more practical. I’ve had my car for a couple of years now and loved owning it every day! Take a look at the pics and judge for yourself. Not to many cars getting around on 18x9.5+10s all round every day, these are my favorite part of my car!
The car needs a new windscreen + castor bushes for a RWC, I can do these if the car sells for the asking price, and otherwise u can get it done.
Item Summary: 1993 Nissan Skyline 4 door sedan
Condition: Used
Kilometers: 145k
Registration: September
Asking Price: $7900
Delivery Methods: Pick Up
Contact Info: call Aaron on 0411797868
ENGINE:
• RB25DET
• 5 Speed Manual
• Nismo Heavy Duty Clutch
• 3" Ganadore Exhaust (street legal)
• Aluminum 100mm radiator
• Standard Turbo
• Standard Manifold
• Cooling Pro Intercooler Kit and piping
• New Spark Plugs
BODY:
• Factory gun metal grey
• M-spec bumper
• Rolled rear guards
WHEELS/SUSPENSION:
• 18x9.5+35 G-max Energy rims all round
• +25mm bolt on spacers all round giving the car a +10 stance
• Pirelli P1 Semi slicks (fitted 4 months ago, still good)
• Bilstien Shocks, super low king springs (still at legal height)
INTERIOR:
• Pioneer head unit, Pioneer splits, Amp + Boot mounted sub (see pics)
• Blitz turbo timer
• Stewart Warner boost gauge
• Standard interior
Sorry no interior pics as yet, I will upload some soon
SPARE PARTS
• I have a set of fiberglass side skirts (unpainted) I can have them painted for $200
• 4 Standard rims + tyres (tyres are un-roadworthy)
• New boot with led tail light (non spoiler boot)
There are a few small dents in the bonnet, roof, boot and one near the filler cap. The dents were caused last year during the hail storm. I have a replacement boot with tail light (needs painting. I can take pics on request if required
SORRY THE REST OF THE PICS WONT UPLOAD, ILL TRY AGAIN LATER
https://www.sau.com.au/forums/topic/353447-r33-sedan-4-door-rb25det/
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
