Dunno if I'm allowed to post this sorta stuff but I was extremely close to buying this car, flights booked to Perth and all, but then something told me to get this car checked out...
Made the owner take it to a mechanic who then told me it was f**ked.
98psi on #1 cylinder and 180psi across the rest. Brakes were metal on metal and motor was knocking...
This was probably 4 months ago now and he hasn't removed the listing or adjusted price. I'm curious as to wether he knew before hand and just wasn't going to mention it to me or not.
Just hope the people out there are doing there homework before they buy cars.
Even the caryards are dodgey as hell. My advice if it's a fresh import: run the vin number through every search engine you can find. I found mine and the info varied between dealer and the advert I found.
TRUST NOBODY and remember; you are doing them the favour by buying the car, not them doing the favour by selling it to you.
And most importantly get the car looked over (compression and leak down test is a must)
If I'm not allowed to post the link below please delete mods
but I'll leave this description:
pearl white 260RS in Perth, dayz options, 34GTR wheels, un-necessary fuel and intake mods...
Good luck and thanks for listening to my rant ;)
http://www.carsales.com.au/used-cars/private/NISSAN/STAGEA/details.aspx?__Ns=pCar_PrivateSpecialFlag_Int32%7c1%7c%7cpCar_ImageCount_Int32%7c1%7c%7cpCar_LastModifiedDate_DateTime%7c1&__Nne=20&R=8854702&Cr=4&model_id=4606&__N=4294960181%204294963846%201216%20834%20285%20257&silo=1003&seot=1&make_id=5&__No=60&trecs=74&__sid=128FD21CE450
Edited by Brendan260RS
https://www.sau.com.au/forums/topic/353455-dodgey-dealers/
i don't think i'd even get as far as a comp/leak down test....things like 'gearbox sticking in third (because i thrashed the synchros), just needs oil (and a rebuild) but i can't get the drain plug off (because i rounded it off trying to open it with a sledgehammer).'
or
'rear shock needs replacing (including all other rear suspension components, cradle, and HICAS most likely shot to pieces) after damage with a gutter (which i fully sik'd into).'
https://www.sau.com.au/forums/topic/353455-dodgey-dealers/#findComment-5665598
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
