Hello my name is TIB i live in the uk and drive a R33GTR i joined this forum as there is a massive amount of info on here about the rb30 and i plan to build my self one.
i am also a member on the GTROC forum (MrGT) some of you may know me from there, most people in the uk dont seem to have the same "i can do that" attitude you Aus lot have,
and not many people other than big tuners in the uk build rb30's. but im not one to follow the masses so i will be building my own rb30.
but heres the spec to my car and a few pics of it i hope you like her, comment welcome
spec:
RB26DETT
HKS air filter
pollished twin turbo pipe
HKS steel headgasket
HKS inlet and exhaust gasket
HKS oil filler cap
chromed plenum
Autobahn 88 water pipes and rad pipes
large volume ally rad
Nismo rad cap
garage sarus ecu
Greddy oil pressure gauge
Greddy boost gauge
Greddy pro fec bboost controller set at 1.1bar
blitz turbo timer
OS giken twin plate clutch (600bhp rated)
RS-R ex mag concept cat back exhaust
De-cat
Trust (Greddy) down pipes
EBC yellow stuff pads
4000r front and rear bumpers
18" compomotive mo's wrapped in goodyear eagle f1 tyres
https://www.sau.com.au/forums/topic/353457-rb30-fan/
depends how long it takes me to read all the info on rb30's on here, could be a while lol.
firstly reading up and getting a list together for everything i'm going to need, and the car is about to go of road for a single turbo converion
then i'll start collecting all the bits for the rb30 build.
its just a shame rb30 blocks arent as easily sourced in the uk like there are for you lot, a mate of mine recently came bck to the uk from a 4
year stay in aus and he was tellin me they are $200 for a used rb30 engine, i could'nt pick up a rb30 engine that cheap over here it would be 4x that amount easy. :(
tib
https://www.sau.com.au/forums/topic/353457-rb30-fan/#findComment-5663860
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
