Shell ca18de auto now with a rb20det
Tein ha coilovers all round
Z32 front break upgrade
3inch zorst from turbo back no cat or mufflers
Safety 21 5 point half cage
Gates timing belt
Alloy radiator with drift thermo controller
Hypergear tr43 top mounted and ext gated at 17psi made 207rwkw then coilpacks broke down
Gtr 444cc injectors
Z32 afm
Plazmaman cooler pipes to 600x300 Cooler
Gizzmo ebc 6 presets
Nismo short shifter
Nistune ecu tuned by Trent at status
$6500 firm
Selling to buy a bike
Edited by gelousi
https://www.sau.com.au/forums/topic/353473-rb20-powered-s13/
Hey mate I'm in reservoir, I don't really want to trade for a bike but I'm chasing either a ktm525 or crf450 plus cash my way
Thanks Loky I'm going to miss it, still having 2nd thoughts to sell it :(
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
