Alright. Due to not enough money to go time attack racing every couple of weeks, and better places to spend my money. I'm putting my 350z up for sale. Car was built approx 3 years ago, and has only seen a few track days since then.
Make:Nissan
Model:350z track spec
Year:2003
Engine: VQ35deTT
Mileage less than 20,000km on shell, probably 6-8 track days on all the parts
Gearbox: 6 speed 350z
Engine:
Engine was imported from the states as a crate motor. It features
Forged pistons, forged rods, HKS metal head gaskets, HKS cams, aftermarket valve springs, lower compression ratio for turbo application
APS twin turbo kit has been fitted, this includes, twin turbo's, manifolds, twin entry single exit intercooler, APS bov, APS larger capacity sump
660cc injectors (presumed HKS), aftermarket larger TB, BULLION billet power steering and overflow resoviors,
FAST 1000hp fuel pump, FAST fuel regulator, FAST inline fuel filter, 2litre surge tank, all high temp hoses. Walbro 500hp lift pump.
HKS platinum spark plugs, GReddy oil cooler kit, power steering cooler, KOYORAD alloy radiator, custom alloy shroud with twin SPAL fans,
Motec M800 Engine managment, Motec fuel pressure, Oil pressure, Oil temp, Water temp, Boost pressure, Boost control kit, Motec Firewall plug, air temp, twin lambada sensors (wideband)
Motec unlocked for everything apart from VCT. VCT wired however while tuning motec was unavailable to release code for VCT enablement. MOTEC CAN plug and USB cable included.
Motec sports dash in interior.
Suspension:
Custom valved TEIN circuit master coilovers with EDFC
Ikeya Formula Front Lower Arm Bush set (Removes standard rubber push and replaced with rose joints)
Ikeya Formula Tie rod kit (Tie rods and Tie rod ends)
Ikeya Formula Front Pillow Adjuster Link (front adjustable upper arms)
Ikeya Formula Multi Link Spacer Alloy (Solid rear cradle bushes)
Ikeya Formula Rear Camber adjuster upper arm (camber adjustment)
Ikeya Formula Rear lower rod (replaces factory lower arms, removes use of factory spring, allows for coilover use)
Ikeya Formula Rear lower link (toe adjustment)
Ikeya Formula Traction adjuster rod (traction adjustment)
Ikeya Formula Rear knuckle pillow bush set
Whiteline adjustable front and rear swaybars
Interior:
Bride Zeta 3 seats on bride rails, driver and passenger.
Willans 4 point 3" harness, driver and passenger, FIA date 2013
Motec sport dash, Nardi classic steering wheel, custom wiring to switch panel and fuse box on dash, kill switch on dash
Hydrolic handbrake, Stripped interior.
Cams approved Roll cage. 16 point from memory.
Fire extinguisher in centre console area
DEKA dry cell batter mounted in rear seat area.
Dash skin still in.
Stereo: N/A
Exterior:
Standard 350z body kit.
Carbon fibre vented bonnet, Carbon fibre hatch, Carbon fibre roof and pillar overlay. All genuine Seibon
Perspex rear window
Series 1 headlights and taillights, few marks on paint as expected on a track car.
Driveline:
Jim wolf aluminum flywheel
custom 6 puk clutch by NPC with uprated pressure plate
Braided clutch line
standard 350z 6 speed gearbox
Carbon fibre tailshaft
Nismo 2 way mechanical LSD, can be adjusted to 1.5 or 1way
Standard 350z Brembo's, stock rotors and pads still in.
Wheels & Tyres:
Can come with either
Volk Gt-V 17x10 +15 all round in chrome
or
Work CR KAI 18x9.5 +12 all round which need paint.
or
Provide your own wheels.
Tires can be negotiated.
Extra Details:
Car was tuned by 101 motorcafe, It made 448hp at 10psi. very safe, injectors were at 61% duty cycle.
since tune a leak in cooler piping has been located, will be fixed and taken back down for a retune to ensure engine stays healthy.
Car has run a 59.53 around lakeside recently, On stock brake pads and no aftermarket aero, running on Federal FZ201 tires.
With a good set of pads and some aero (rear wing, front splitter) it should easily shave a couple of seconds off that time. Some proper slicks and it will go faster again.
Could also be eligible for Targa, unsure on the regulations, best to check targa regs and rules on registering an import for rally use.
Item Condition:
Excellent, not alot of work on any of the parts. All parts used are genuine, no chinese rip off parts used in this build.
It's very quick, and will not disappoint. few minor adjustments and it will be a very fast time attack car in the 2wd class.
Of course with a car this calibre, there are probably numerous things that have been done that I've missed out. I'll attempt to update this if I remember anything else.
Reason For Sale: Not enough time and my heart just isn't in circuit racing
Contact Details: Daniel. 0427282562 or contact here
Price & Payment conditions
Cash. Not interested in swaps unless there is a bulk amount of cash coming my way, and the item is of interest to me.
I am looking for around $52,000, much more than that has been spent on this build, in excess of 150k has gone into this car.
Edited by Buckna
https://www.sau.com.au/forums/topic/353477-350z-track-car/
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
