Hey, just a quick question, today I had my spark plugs replaced and gapped at 0.7mm hoping to fix my minor misfiring issue. It still hasn't made a difference so my next and final port of call are coilpacks (after checking everything else) so I was wondering if I got new coilpacks, am I still alright to keep the spark plugs and the gap of 0.7mm?
If it's not alright what sort of problems will I run into if I kept the gap?
Plugs are heat range 6, copper and 0.7mm.
Cheers.
https://www.sau.com.au/forums/topic/353511-re-gapping-plugs-for-new-coilpacks/
Thanks for the replies guys.
Sorry, I forgot to mention the car is making 194rwkw @ 12psi (standard turbo).
So should I get new plugs gapped to 0.8mm with a heat range 7 or am I ok to continue using the new ones I dropped in today?
Cheers.
Alright then, no worries.
I'm looking into the Yellow Jackets as they seem to have a pretty good rep and are good value for money. Yeah, I've read that the standard coils are excellent but cos abit over $1k though :(
So if I left it gapped at 0.7mm witht he new coilpacks, is there any sort of negative effects that I might induce (eg. fouled plugs, overheating coilpack etc.)?
Cheers.
I'm running a 1mm gap @ 150AWkW & heat range 6 (I think) in my RB25DET, with Splitfire coils. Don't have any sort of problem with misfires or the like.
They aren't hard to remove and regap if you are worried.
I think you can get the stock ones for around $500 from the US.
Alright then, no worries. I just wasn't sure if they're is any negative effects on the car if I ran a close gap with a brand new set of coils.
I prefer something local so I'm pretty keen on the Yellow Jackets :thumbsup:
Cheers for the info. What boost are you running?
The bigger the gap. The better the spark (if the coilpacks are strong enough) bigger gap can increase torque
Ooooo, I see. So let me see if I get this right:
- weak coilacks require a smaller gap so that there can be spark, but itsn't so good for performance (but can eliminate misfire)
- coilpacks with a strong punch can utilise a spark plug with a larger gap (due to being able to create a bigger spark over a larger distance) and can increase torque
- running a small gap (eg. 0.7mm) on a set of new coilpacks isn't "bad", but not doing myself any favours in terms of performance.
Correct?
spend $24 and put BK7RE in . pregapped .8 heat range 7.
Im gonna have to do this and try... siliconed up the coil packs today and not much change in the deadness zone after around 4000rpm+. I pulled the plugs out and cleaned them up while I was at it. (Battery went flat and I wanted something to do while it was charging). Will replace the plugs during the week... might have to try a $20 VN commodore wasted spark setup since I cant justify spending $400 on coil packs for a car im going to sell soon.
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
