it sounds like cv's but it shouldnt make any difference what gear you are in as long as you are turning especialy full lock , it may only do it turning right or left or both sides .
go in a culdesack put it on full lock then take it out of gear if it still does it then icv's for sure .is it a 4wd ? if yes front cv's if rear wd then driveshaft cv's
hey man
Its not the cv's...coz the sound also happens wen taking off in a straight line as acceleration increases then goes away after 2nd....wat do ya think??
could be a ****ed cat... reach under and bang on it see if it rattles.. if it do.. take it off and "fix" it with a crow bar...
na its not the cat...its brand new with compliance only 3 months old...il check it anyway....its a strange sound ...i was at a car park today...reversed out of my spot and took off in 1st then 2nd and the noise happened again it only happens under 50ks then goes away after speeding up.
Its like a chaing being dragged on the ground once the accelerator starts bein pressed harder till it stops over 50ks.
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. 😭
    • If you don't touch the CAS, then you're fine.
