First Speeding Fine. How Do I Get Out Of It?
Hey guys. I got a speeding fine in the mail about a month ago but with a 21st, work, a poor memory and no organisation skills its taken me until now to wite a letter to contest the fine or have it reduced to a warning.
I was done by a car on the side of the road. Recorded speed was 58 and alledged was brought down to 55.
It's my first fine since getting my P's 2 years ago (Admittedly not a great deal of time) but a few mates said that since it was a first offence and under 10km's over, I should be able to get off. But having not written a letter themselves or simply forgetting what they wrote, they werent much help in telling me what to write.
Anyone had any experience in the same situation? Any suggestions on what I should be writing?
Worst part is that it's a couple of streets from my house, I always see the car/camera there and I'm usually making a concious effort to drive 5 km under the limit past it.
Edit: Fine was $159 dollars and 1 point
Edited by bob182
I might just pay up now. I'm working full time and I can't see myself getting into any real trouble with demerit points in the next few years of P-Plates.
As a side note. I am all for speed cameras, but since I was caught on a staight, empty road at mid day in good weather conditions, maybe police need to start thinking about putting them in areas where speeding is actually dangerous. But I cant complain. Done worse withut being picked up in the earlier days of P-Plate driving. probably why my corolla over-heated
Don't worry bout it mate you will NEVER get out of a SPEEDING fine unless (and I'm not reccommending this in the slightest) you have someone take the points/fine for you.
As for all other demerit offences (not hooning stuff) you can opt for a summons as opposed to an on the spot fine/demerits. That's always good if you need to delay things a bit :happy:
lol...i did...saved me the cash but that as only because i was able to prove wrong speed signs...some place in the country side....cant remember where but was a while ago....
but in general you made a mistake...n got caught...so learn ur lesson and pay for it...
Off your high horse everyone!
Read this Bob... http://www.police.vic.gov.au/content.asp?document_id=10369
Sounds like those criteria accord with your circumstances, so you should be able to get out of it. Writing the letter should be reasonably straightforward, so long as you are reasonably coherent.
Good luck, and stop speeding :domokun:
  • Like 2
I wrote a letter and I had my fine reduced to a warning (no points deducted either). See the web page as linked above. You need to admit your fault, and refer to the fact that you have not had a fine or pardon within the last 3 years.
When I was let off the 5kph fine I had not had a fine previously for over 5 years. The previous one was for 24kph over, and the one about a year before that was 11kph over.
Getting out of a fine is not hard. Being on P's didnt used to do you any favours (and infact they used to honor the fine and points) but times might have changed. As much as it frustrates me to plead guilty and ask for forgiveness in the 4kph over on a highway bracket, the issuing officer has always written back a warning and removed the 1 point and fine.
If you write a carefully written letter and you have an excellent driving record. You have a chance of getting out of it.
I know two people that have got out of their first fines :)
If its your first offence under 10km over you will get out of it just as other said admit you made mistake say was split second of carelessness and you have learnt from it blah blah and if you could please have a warning. I did it on my first offense on my Ps got off.
Thanks for responses guys. I may as well take 10 minutes to write a letter. I cant have any complaints if it doesnt work.
Seems worth a shot.
I'll post back in a few days or whenever I get a response
MATE!! all these people on here are all wankers.. majority of them are gunna tell you.. pay the fine learn ur lesson.. but you know what cause they dont have any balls to stand up and cheat the law like 95% of people do f**k them.. do it for yourself what havet you got to loose nothing... you loose the contest you pay the fine. you win you dont pay ... trial n error dont worry bout these tools who have no idea how t5o get out of one... go to a mechanic and heyll help u out..
    • You will need to extend the turbo inlet pipe somehow, which could/might be done with silicone/rubber pipe, but might need steelwork, depending on your intake. And you will need to change the pipework on the outlet in teh same way, but this is more likely to need steelwork.
    • I see... Any idea how much fab work is required? I note the Hygear megathread but its like 900 pages
    • I should try the experiment you're talking about, the throttle switch is still there carried over from the R32 and it's still all wired up but after I did the whole intake manifold refurb and had to recalibrate the TPS I managed to somehow get the idle switch reporting activation at 0.22V, then when I adjusted it to 0.45V for idle it decided the engine was permanently no longer idling which caused some very weird behavior, closed loop idle was disabled so it would basically be at the whims of the cold start valve and whatever the base timing table was at. Then just unplugging/replugging the TPS with the ECU live caused it to relearn the idle TPS position and decide 0.45V was idle. Presumably there's nothing in the TPS that allows for the throttle switch to "recalibrate" like that, not easily at least.
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
