Hi guys,
I'm looking to purchase a R32 - specifically this one: http://www.carsales....Location_String
Does anyone know anything about it/the owner? & Would anyone be willing to come check it out with me...because i'm a total noob when it come's to skylines. I've grown up restoring & racing old Fiats (Insert joke about old Fiat's here) So not really savvy to common problems etc..
Being a P plater (Green's- till november) I thought this one would be perfect, as I can put the old engine back in..
Thanks!!
LS
Edited by ls128
https://www.sau.com.au/forums/topic/353530-new-to-skylines/
Hi guys,
Thanks!!
LS
Go for a r33 gtst your better off
https://www.sau.com.au/forums/topic/353530-new-to-skylines/#findComment-5665010
Green P plates = no mods ?, a 25 in it may be a legal/RTA problem mate.
Yeah not sure, I would hazard a guess saying it's not engineered. Most likely if I did buy it and get defected - i'd get it engineered (at a cost :( )
*Edit - mlr, have you ever been to motorkana's with SSCC? I live around the corner from the president of SSCC..I believe.
Edited by ls128
https://www.sau.com.au/forums/topic/353530-new-to-skylines/#findComment-5665026
Personally I would wait till your on your full licence, and then get something else, why was the motor changed ?, lots of bargains out there if your willing to wait and then low ball some sellers.<BR><BR>Its a buyers market out there with the new laws for turbo cars. <BR><BR>No khanas with SSCC yet, ones coming up at the creek but Im not sure if Im available, stupid work.
https://www.sau.com.au/forums/topic/353530-new-to-skylines/#findComment-5665037
See, I would. But currently my Fiat X19 has blown its head gasket - so i'm taking that opportunity to completely rebuild the engine, and I work fulltime in ultimo - at the moment am driving my parents honda CRV there every day , plus they don't want 120k a day added onto its mileage..- I need my own reliable daily driver. Because honestly, the Fiat will never be reliable! The fiat club of nsw has motorkanas - SSCC has attended them several times the last 2 or so years!
Edited by ls128
https://www.sau.com.au/forums/topic/353530-new-to-skylines/#findComment-5665042
Nah, I want something I can enjoy for the rest of the time - hence going after a skyline, if I wanted something just to run around in then I would get a 4cyl toyota or pulsar or something.
Pics!
And Yes Tony, whilst the head is off, a few hp additions will happen..I've had a ride in a Delta Integrale...wow.
Edited by ls128
https://www.sau.com.au/forums/topic/353530-new-to-skylines/#findComment-5665069
There are certainly exceptions out there but I wouldn't buy a Skyline of that age that's already been tampered with if you want a reliable daily driver :)
If you do decide to go ahead, could get a workshop to go over it and give it a thorough check?
https://www.sau.com.au/forums/topic/353530-new-to-skylines/#findComment-5665114
That was my plan - hence asking someone here to come along, so if they notice something right away, they can tell me don't do it , and save the money of an inspection.
Do non turbo r32's come up often?
https://www.sau.com.au/forums/topic/353530-new-to-skylines/#findComment-5665122
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
