New To Skylines
ls128
 Share
The majority of N/As that I've seen have been autos. In fact I can't even remember having seen one that wasn't (not that I'm saying there aren't any out there).
I know it's not what you want to do, but I think you'd be better waiting and you'll probably end up with a better car in the long run when you're ready and able to drive the turbo.
If I found a nice 33 for the right price then i'd get it no hesitation....my kinda goal is to get something fun now - to last me a year or so, so I can save up & buy something way better part way through next year.
I completely agree with you Tony, however that one I linked is a 32 with a rb25, just comes with the rb20 motor as a spare..Perfect for when I get onto my blacks.
Take advice from somone who wated there money on a NA DONT do it.. TRUST me you'll regret it so much later that extra money you spent on a NA skyline that barely moved could have gone towards more mods on your new r33 ... Just take my advice trust me your going to hate yourself later :)
Sid
Tony - I don't think so, would have to check with the buyer...Speedwhore, The guy isn't asking a huge amount of money for it - and it comes with the original motor!
Yeah - Don't start me on the MR2. Toyota has admitted to importing a X19, stripping it and basing the original MR2 on it!! Kinda wanting to not have a two seater, as i'm usually designated driver! I raced against one at Wakefield Jan this year, though it was turbo. Didn't seem to bad - that being said, he had more spins then I did...
The MR2s are little less forgiving on the limit, a lot better after 92 but the brakes arent great in stock trim.
Shame about the 2 seats though.
You might have rego dramas w/o engineers report onthe 32 though.
328i? 2j Supra N/A? Maybe too $$
Edited by Tony Brown
Not sure what year it was - def one of the older ones though. Yeah I know that it may have dramas with rego without a engineers report - but it has rego till jan 2012, by then i'll have my blacks and hopefully the turbo motor back in & engineered for that (if it even needs it?)
As for a 328i - i've looked at BMW's and Alfa's - Eurpoean. I've learnt my lesson with European cars & Parts. Costs a sh1tload. Even at mates rates! Never really liked the look of Supras, but would be open.
I guess that doesn't leave you too many options, RWD N/A 4 seats, japanese and fun to drive......just about explored all options here and since we are on a Skyline forum, then it could be an RB25 powered 32 since its potentially the best "bang for your buck" car in N/A for your circumstances.(only if you can beat the price down a fair bit, a non-engineered conversion is not worth that kind of money IMO)
Hell I just sold a R34 GT-T auto sedan for $8500 http://www.skylinesaustralia.com/forums/topic/352396-r34-gt-t-auto-sedan-in-canberra-8500/page__st__20__p__5664504__fromsearch__1#entry5664504 thats only $1600 more than the car you are looking at, and while I understand that it would not have suited your needs, just comparing value for money makes the 32 look more like $3500 than $6900
I am all out of suggestions.
Good Luck, Tony
 Share
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stop on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, you need to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
