  • Replies 199
it seemed to go about its business quietly,. but didnt look on pace all weekend. not sure if thats a comparison of where the cars at or they had issues.
We struggled with getting to know the track more than anything else as first timers....and then getting a clean lap without red flags on the Sunday when cars were blowing engines most everylap in the WTAC 'wrecking yard'. IMO the car has a fairly easy 1.39 in it as you would expect from its Mallala pace. This weekend was about having fun, helping out our customers, and bringing it home in one piece. Although I would have liked to have seen faster lap times - you cant have everything :)
As a positive we didnt have a single mechanical issue with our car, and one of our GTRs won Clubsprint. The GT Auto car which uses a lot of our transmission technology also lapped well and was fastest GTR of the event, and now in Australia.
The Willall GTR posted the highest indicated straight speed of any car that we saw (including the pro cars) at 254km/h on the start/finish line - showing that we still have what it takes in the GTR drag game if nothing else :closedeyes::thumbsup::cheers::pirate:
Setup and tyre selection is the key for EC by the looks of it. We will make sure those two variables are where they need to be for next time :)
The driver did a very good job considering the corner speed we were giving away with a total lack of grip...kind of my mistake that one too!
After simons small misfortune. was really expecting a 'drifters dropping oil from you Martin', poor form, lol
car looked damn quick down the straight, but as you said looked to struggle a little bit with corner speed, particularly through turns 6 and 7
hope Gareth has a nice new outfit for saturday :wub:...lol
Who or what is a Simon and what misfortune?
I believe this is a Simon, and this is/was his misfortune
back from WTAC and not a good result :( motor spun several bearings after just 7 laps. dropped oil from a failed oil cooler fitting on first lap out and then fixed it up and filled it back up and it seemed ok. but 7 laps in and it started rattling really bad.
haha, you get those 295's from the pits after?
I was gonna grab them but just alittle to wide for me :(
Yep - couldn't resist the price...... Sorted for Legend of the Lakes now, and perhaps a single lap flyer at Mallala!!
I had plenty of time to look at that radar (courtesy of sitting up in the tower with nothing to do) and it was reading differently depending on where it picked up the cars on the track.
For the record, Sierra Sierra logged 298km/h (on their own data logger) at one stage ;)
Edited by Iron Chef
yeah, cost him a motor sadly, id say/ hope he's going to improve the set up, as its not the first time its popped off
Maybe thats not bad luck then - its not often you get a warning to fix something like that and get away with it in the first instance....
As for the speed trap Iron Chef, it was very hard to work out how and where it picked up even watching it closely.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
