find an adaptor plate (they do pop up every now and then on ebay/sau and other site) once you have that it a matter of taking off the old and putting on the new. May not be as simple as it sounds.
What power/mods do you have now?
If you look half way down this page you will see all the parts together with the adaptor plate i was talking about.
Edited by Boss-zilla
rb26 plenum is not bolt on and requires alot of work and custom work done.
Its pretty much an engine out job
It's not an engine out job if you have the right tools and small enough hands to get to the bolts that hold the top half of the plenum on.
But yes, RB26 plenum to RB20 isn't bolt on, there are adapter plates available for a pretty penny. I made my own out of stock runners and an RB26 plenum chamber but you can also buy some on ebay, I know people using a KU Engineering plenum with success.
luvboost - have a look in the "projects, overhauls and builds" section of the forum and find the thread that ROY started "a boy and his love for his RB20"
if you can't be bothered reading it... the short version is that his 270rwkw RB20 using stock plenum etc was replaced with a fancy front facing plenum from plazmaman..
end result was worse than stock and eventually retuned to be almost as good.
for many MANY thousands of dollars.
even shorter version - don't bother changing the plenum.
Slightly better response wise maybe but shortening the runners on an RB20 isn't a top idea.. they already suffer a lack of torque. Shorter runners mean less low down torque but better cylinder filling at high rpm so, it will be laggy but scream like hell to redline :laugh:
I only did mine because it's a 3L so has an abundance of torque already and I needed the height clearance.
Edited by bubba
as above, shortening runners on rb20's not a good idea
i have put on plazaman plenum (same as roy in build thread mentioned above) my car is rb22 specifically tuned for high rppm for drift... i got 200 rpm more response and a decent more power held for longer at higher rpm... and a neater engine bay
but.... i have everything already and it was the last thing i did and wouldnt say it dramatically increased performance... unless you want a nicer engine bay or really really want to do it... leave it as is
its not abut removing the std plenum that is the issue. When you add the a adapter plates the extra length pushes the plenum outwards further and the gap between the plenum and body is very small. Due to the 1st section of te plenum having long studs on it and the size of the plenum itself it becomes very hard to split the plenum onto the stud due to the space.
Also it is alot asier to hookup all the vacuum and heater hoses which go underneath when the engine is out.
hey guys ive got exhaust, front mount, bosch 040, z32 airflow, gtr injetors, apexi avcr, apexi afc neo, apexi pod filter and just the stock turbo but the turbos getting changed soon! i want to put it in also to clean the engine bay up. i hate the side facing plenum look
its a big job for very little gain.
i'm not sure if they make the greddy plenum for rb20, but even that will cost you around $900-$1000 for a real greddy plenum or $300-$500 for a china copy then you have the install cost.
If i was you i would sell the afc neo and get yourself a rom tune done you will get alot better results and the car will run alot better also (think its call niztune or something for the rb20, i know hyperdrive can do them)
Edited by Kaido_RR
GReddy do not make an RB20 plenum, the only off the shelf complete replacement (not just the top half like Plasmaman) solutions are ebay jobs such as the KU Engineering plenum.
That being said, Plasmaman is probably the best bet as you retain the longer runners.
so its not really going to work then :( what about if i put a different head on like 25 26 would that change the plenum i could use or not. i dont no much just asking
not really worth the coin and im not sure if a 25 or 26 head would fit and there would be alot of stuffing around and at the end of the day what it would cost you would be cheaper to just do a 25 swap and put a greddy plenum on that when the engine is out
so with the rb26 plenum it has shorter runners and the rb20 has longer ones? what if i could get a plate made up for the rb26 that makes the runners that same size? would this work or still lose power
cheers for the help so far :)
No it wouldn't work.
If you really want to spend some money, get a plazaman or hypertune RB20 plenum that sits on the factory RB20 runners.
The RB26 plenum conversion from the results I've seen on a mates RB25 was horribly expensive and not many gains.
Also dont forget to factor in the cost of making up new piping to the intercooler on the intake side.
    • interestingly enough, i found out the answer is yes. doing a flush did fix my recurring A/T light. it might have been because of the trans filter: but that doesn't really make sense to me. the fluid/filter was super dirty. would that increase the pressure in the lines and trigger an A/T light? does the car even have a way of detecting that? i have no idea. i've done 200+ miles after the flush and no A/T light. if my A/B solenoids went bad, i would think the light would've come on. shifts and drives way better now though...at 2k rpm instead of 2500...no hesitation and downshifts when i want it to.
    • I vote go red. Only because I hate keeping gloss black clean. Was no worries helping out either! Glad you've survived the rain outs of QLD
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
