custom shortened upper arms and extended lower arms for that much camber. have seen worse again....so much camber the stickers on the surface of the tyre don't even touch the road!!!
this is not a photo shop! there are vids of it driving here
http://www.7tune.com/oni-camber/
https://www.sau.com.au/forums/topic/353584-m35/page/2/#findComment-5666189
  On 11/02/2011 at 1:25 AM, Sidius said:
i want a slight camber on my stagea tho , how would u guys recomend doing this ??
custom arms or??
You'll find as you go lower, you will induce more static camber, at the height my car is (avatar pic) it has around -1 deg front & rear. But it changes RADICALLY if you go an inch lower than that...
You can use adjustable upper arms for a G35/350z, I believe, or fulcrum do aftermarket eccentric bushes as well.
http://www.fulcrumsuspensions.com.au/superpro.html
SPF3297K
Front
Control Arm Upper-Inner Eccentric Kit
SPF3313XK
Rear
https://www.sau.com.au/forums/topic/353584-m35/page/2/#findComment-5666948
custom arms or??
Just try your BC's first. when they go a bit lower, the wheels tuck quite a bit.
They can have that camber BS IMO. Great way to reduce grip/power and make it undrivable.
https://www.sau.com.au/forums/topic/353584-m35/page/2/#findComment-5667106
