I am wanting to organise a group buy for the SpeedM8 CANBUS delimiter for Skyline 350GT.
They remove the limit without affecting any functions of the car.
http://www.ncs-systems.com/prod/1458
£179.95 each for 1 units
£129.95 each for 2 units.
£122.52 each for 3 units.
£107.00 each for 5 units.
Anyone in Bris/GC wanting them please let me know. Prices do not include shipping, once we get a total amt i will get costs on shipping. Im assuming $5-$10AUD more on top of unit price if we get 5 units.
If you are outside of bris/gc then you gotta pay additional postage ($7.40 for express post).
https://www.sau.com.au/forums/topic/353590-speed-delimiter/
is this a plug unit to the diagnostic port or does it require splicing wires into the ECU?
I've yet to take my car to the 180km/h factory limit, but would be nice to have for ppl that track their cars.
Wiring Details
  • White / Blue - CAN HI & CAN LO (LOOM)
  • White / Green - CAN HI & CAN LO (ECU)
  • Red - 12V+ Supply
  • Black - 0V Ground
Looks like wiring. Two wires, any auto elect can do for cheap.
https://www.sau.com.au/forums/topic/353590-speed-delimiter/#findComment-5666272
you are playing with the main LAN in the car - good luck :)
also freight from the UK for any reasonable timeframe will be $30-40 AUD.
So Chris are you saying that this is likely to be a problem/dodgy product or just require careful installation practises?
https://www.sau.com.au/forums/topic/353590-speed-delimiter/#findComment-5666886
nothing about the product.
I'm saying two things for the DIY crowd:
you are playing with the main CAN lines on the car. destroy something here and you are really up shit creek as parts get expensive quick.
if you don't know what it is - DON'T FK with it.
I understand the concept behind the thing. look for the speed address and write another value to the CAN network when a certain point is reached. the issue comes in when it possibly writes to another address and upsets something. the other thing to bear in mind is that this thing maynot suit your ECU.
can you back up your findings with ECU part numbers?
https://www.sau.com.au/forums/topic/353590-speed-delimiter/#findComment-5667127
Dont worry, i aint installing ANY ECU stuff myself ! I know where my DIY limits are !
Can you explain further on ECU part numbers? As in what i will need to ask them and ill post back. It does say 350GT and not 350Z or G35..
Postage cost will be $30-$40 so divide that by 5 and its under $10 each.
Edited by R6n350GT
https://www.sau.com.au/forums/topic/353590-speed-delimiter/#findComment-5667164
Nate, I'm positive it will work fine. Dead simple to install too. Anybody CAN do it (pun intended) :)
Obviously check with supplier for definitive compatibilty. I'd have one but I'm not likely to go to the track, ever.
https://www.sau.com.au/forums/topic/353590-speed-delimiter/#findComment-5667595
I want to buy one asap so anyone else???? I have one other person wanting one so 2 so far.
https://www.sau.com.au/forums/topic/353590-speed-delimiter/#findComment-5675153
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
