I figured we should start a seperate thread for this so every one can see it instead of just the people that check out the Townsville and Mackay section.
Basically we are trying to organise a weekend in Airlie Beach over Easter.
Every one is obviously invited so let's make it a good weekend!
Will be a great chance for every one to finally meet and see each others cars.
Chuck your name down in the thread so we can see what kind of numbers we can expect and also to discuss anything related to the weekend here :)
UPDATE
So the meet up shall be on Saturday 23rd of April at around lunch time and a stay over night at Airlie Beach.
All are welcomed and so far we have the following going:
DEFINETELY GOING
PMR33
ROBBO_RB180
89CAL
ROBBI33
DYSONEST
NUR33
KING87
SKITZS RB26 GTST
MAYBE GOING
THE MAFIA
GRANTHEM
  • Replies 204
Got my new lens today. Just been out having a quick play around with it. Looks pretty good.
Should be alright for some nice car photos :)
(not sure how the quality will show up here. It got downsized alot to get onto my iPhone)
Edited by 89CAL
count me in, any one got a good idea for where to go for accomodation or is this a one dayer?
Depends if your on a budget or not
Blue Horizon is one of the nicer ones, at not to bad a price
Or you can go classy and stay at peppers
or you can go cheap as and stay at wanderers
If anyones looking at accom, should post up what you find here. Being easter weekend It may not be cheap.... or available very long
Main thing with accomodation is parking. I can deal with a hotel room not being perfect, I can't however deal with worrying about my car all night because it's parked on the street next to a pub lol.
But yeah, maybe we should post up some prices that we find.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
