  • Replies 204
lol its a 5min job to adjust the tune to supposedly make it backfire.... my car wouldnt drop down to the first row of cells straight after lifting off accelerator. Not sure why but anyway
Might have a play again in airlie
All ready to go I think? Bought a remote trigger for the camera today (Should be good for any shots taken on the tripod) and a mouse yesterday for photo editing on the laptop.
I Will try and remember to put some blank DVD's in to burn the photos to a CD. Either I do some editing Saturday night to give edited photos out on the disc Sunday before everyone leaves, or everyone just gets the raw photos from the weekend :P
got the car all fixed, almost ready for the weekend.
whats the plan for the evening? drinks & bbq at one of the hotels to keep it cheap, then head into town around 8:30-9?
Ah you pussies i wanna at least see one smokey burnout!!!!
what is the cost these days for excessive & undue noise and damage to commonwealth property???
Edited by robbo_rb180
Yeah the BBQ idea sounds good. Whoever has the best hotel (and also easy parking for low cars lol).
Rob the fine isn't worth as much as the respect you will get :P
The burnout will equally approx. 20,000xp points on NFS
Outrunning the cops doubles your points to ;)
I don't care how much i spend this weekend, much like every weekend lol, but yeah i'm easy whateva you guys wanna do i'll do, i got no car to drive so ill be following the crowd, as for the cost of this excessive noise and smoke i estimate approx $300+ and 2-3 points ( i been done for that twice before thumbsup.gif from those f**kers) plus defects. Nice camera setup Cal can't wait to see what i goes like then you can come take photos of my GTR'srolleyes.gif.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
