Price and price conditions: $14,000
Contact Details: pm me for contact details
Delivery & Conditions of Delivery: cash talks, everything else walks.
1993, Mazda RX7, FD3S, JDM model
Fresh 13B engine, secondary bridgeport, SCR apex seals (engine under 100 km's use!)
Endless alloy radiator
Cusco 2 way diff
Volk 16" rims with RE55s tyres that have only done 15 laps of winton.
Bilstein shocks, tein coils
Runs a single turbo, from a s4 rx7
ACE 600x300x100 intercooler with 2.5" intercooler piping
full 3" exhaust, to a single JDM big big cannon muffler (5" tip)
all intercooler pipes and exhaust heat wraped.
Fuel system :
Billet fuel rail kit, with PFE fittings throughout.
880cc primary and secondary injectors
Car is setup and running on E85 fuel.
Single bosch 044,
large aftermarket plastic fuel cell, (rear wheel well cut out, and boot now has flat floor)
carter black race lift pump,
2L surge tank.
Aeromotive billet pressure reg with 0-100psi gauge
Magnafuel billet fuel filter
Pro Force racing 5 point harness, (seatbelts also still in car)
Battery relocated to behind drivers seat
battery cut off switch in cabin
Xtreme rotaries billet short shifter (best shifting gearbox and shifter ive ever owned)
Exedy heavy duty sprung centre clutch.
Aftermarket guages
Stewart warner mech oil pressure
Stewart warner mech oil temp
Stewart warner mech water temp
Stewart warner boost
Oil pressure warning light
has aftermarket steering wheel on it, good dish on it and 330mm.
Car has had every hose and line replaced (inc braided brake lines in engine bay)
brand new RDA slotted rotors
brand new ebc red stuff pads
just about every component on this car has been used for under 100km's easily.
microtech LT10s ecu
X4 ignition box
4 bosch coils
R100 magnacore 10mm racing leads
2L catch can with filter and anodised fittings/lines
Twin JDM oil coolers with braided aftermarket line.
fire extinguisher
quick release flush bonnet pins
AST deletion and Moroso 28lb racing radiator cap added.
Car recently went 1:44.0 at winton in november in its first real hit out with passanger. With more tuning time and playing with tyre pressures and driver knowing what he is doing, im sure the car would run sub 1:40 no problems.
*cliff notes*
bad points :
paint is average, (roof clear is bubbled up and in bad condition. front guard has clear bubbling also. doors and rear of car is fine)
but car is straight and rust free (bonnet is black, one headlight cover is black, front bar is sunken in the middle)
can supply an 'autosalon' spec front bar as replacement anyway.
car is JDM import and cannot be registered for use on the street. (this means you cannot really test drive it, unless you want to pay the $75 for the permit i can get for it),
good points :
basically everything in the car is brand new!
Options :
Can fit & tune car for larger turbo, at your cost, no problems.
(e.g. say a gt35r on 18psi on E85 would probably make 300rwkw.)
reason for sale :
Building new home, will be going o/s soon, have owned it for over two years now and driven it for about 3 hours in that entire time. just dont have time for it at the moment, and would rather sell it and let someone else enjoy it!
https://www.sau.com.au/forums/topic/353605-fs-mazda-fd-rx7-race-only-vic/
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
    • 😂 thanks guys. The diagram i had did not have the breather on it at all. Much appreciated.
    • Geez, engineers fees have definitely gone up. Mine back 2007 cost me all of $300. Mind you, I had to go back to him a few times to get him to write the correct things on the report after he'd inspected it. Things like wrong exhaust size, wrong wheel sizes, etc etc.
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
