:( Hey Everyone,
I have an Gtr R32 for sale.
Very regretful sale but due to a baby on the way, will need to settle for a family car
Would also consider to exchange for an Evo 9
Looking at $38k ONO
Email: [email protected]
contact - 0433 277 823
Only serious buyers please !!!
Below are the list of all the specs of the vehicle and all receipt would be provided
Pics will be provided soon
Thanks,
John
Engine:
· Tomei bottom end ( Pistons, rodz & crank shaft )
· Tomei step 1 head
· Tomei cam shaft 272deg
· Tomei metal head gasket
· Tomei sump buffle
· N1 block (cryod)
· Jun oil pump
· N1 water pump
· Nismo Engine & Gearbox Mounts
· HKS Cam gears
· ACL Race Series Bearings,
· ARP Head & Main Studs,
· Tomei Oil Restrictor
· HKS fuel rail
· HKS 1000cc injectors
· Garrett GT42R turbo
· GT60 turbosmart wastegate
· Custom 3’ screamer pipe
· 6boost manifold
· HKS 4’dump & exhaust
· Custom Oil cooler
· 150mm Greedy Drag intercooler
· Custom Oil Relocator kit
· 2x 044 bosch fuel pump (inside boot)
· Custom 6L surge tank (inside boot)<BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break">
Drivetrain:
· 2 way lsd kaaz rear diff
· 1.5 front kaaz
· Quad Plate OS giken clutch
Electronics:
· Microtech lt16
· Microtech x6 ignition module
· Microtech dash
· Splitfire gtr coilpack
· Greedy oil and exhaust temp
Suspensions:
· Full Titanium ARC front strut brace
· Greedy rear strut brace
· Tein HR Coilovers
Extras:
· Battery (inboot)
· Pioneer mp3 player
· Standard Gtr r32 rims
Car has made 880hp atw on e85 petrol on 32psi
Car has made 510hp atw on 98oct petrol on 20psi
:( Hey Everyone,
Would also consider to exchange for an Evo 9 or Evo 8 Mr
Looking at $38k ONO
Thanks,
John
Engine:
· Tomei step 1 head
· Tomei sump buffle
· N1 block (cryod)
· Jun oil pump
· N1 water pump
· HKS Cam gears
· HKS fuel rail
· Custom 3' screamer pipe
· 6boost manifold
· HKS 4'dump & exhaust
· Custom Oil cooler
Drivetrain:
· 1.5 front kaaz
Electronics:
· Microtech lt16
· Microtech dash
Suspensions:
· Tein HR Coilovers
Extras:
· Battery (inboot)
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
