d'oh! you are not having a good run mate. hope you kept the little tag with the key serial no on it?
how did you loose 2 keys? can't say I'm surprised at the $1000 for 2 new ones. though maybe you can get a discount for having 2 coded at once?? maybe see if they'll cut you a deal on a batch of 4 or 5 keys so you don't have to go through this again!!! :)
Hey Eastes,
Not to be a wank or anything but that video pretty much shows where you keep an R35 GT-R to an internet full of low life car thieves.
OT
That's not really an impressive replacement fee for just a couple of keys is it...
Also are those wheels a standard colour from the dealer ?
White car dark wheels = sexytimes.
Edited by Nee-san
Hey Eastes,
OT
Lol. Okay, you tell me the address where I keep the car :-)
Lol You've got a point, but all you need is the suburb and then one of the various mapping programs on the net can do the rest !
Or should i just go back to making my tin foil hats ? :P
Edited by Nee-san
It's $1000 for just one key. I heard merc keys start at $2500!
Previous owner lost one key. I think my key is at a lost found department in one of many Airports in Australia. I tried MEL and BNE, where I flew. Offered reward. No response.
Ha ha, nope. Not the best run. :-) I'll live though!
Edited by eastes
:P
an even easier option would be using one of the many free ip sniffers
some computer geek will spend 5 mins on google and that vid isnt necessary
that's why you insure your sh!t
mate bad luck about the keys, seems the dealers are rolling in the gtr parts tax too
Edited by domino_z
Sorry, didn't see this question before.
They are stock wheels. They're pretty dark normally, but they are a little dirty as well. The brake dust dirty's them up very quickly.
Sounds like an Insurance brokers words :nyaanyaa:
You are right though, the address is easy to find with or without the video, get insurance.
I thought it was difficult to claim under certain policies if the cars keys were used. EG: break into a house and steal the keys and drive away? What i've been told so could be bullshit....
Have a look here
www.courtesyparts.com
You can land a couple transmitters here for $250 direct from the US but what will Nissan charge you to code them especially if you dont buy them through them? Can anyone with a Consult III do that for you?
Dealership said the transmitters cost them about $250 including keying if I do them at the same time. I'm going to get a spare one of them.
So they get you two transmitters for the same price as you can get them from OS and then they slug you $800 just to code them!!! ( I presume you are talking about two of them as that's what I'm talking about for $250). This is for something that should take them all of 30 minutes. That just plain robbery. GT-R tax strikes again :wacko:.... Can this work be done on any Consult III or do you need the "authorised dealer" codes?
Edited by fungoolie
No. Sorry, I didn't communicate very well. They only charge me around $250 for the transmitter part. The little old-school steel key part is nearly $700 that has to be imported from Japan. It's a dimple key with little dimple holes drilled through it. Why is costs nearly $700, I don't know. Plus, on the GT-R, it's never actually used.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
