Hey people, long time member, new poster :)
Well the names Jarrod i'm 18 and live on the Gold Coast ;)
Got bored today so thought i just come on and chuck up some picks of my car :)
Now i know most of you will probably HATE it (most people do) but oh well, its my car not yours and the decisions are mine to make :D
So it's a 1990 Nissan R32 Skyline GTS 4-door.
RB20DE :(
Standard exhaust with rear muffler cut out and replaced with straight pipe.
Automatic :(
Stock suspension and brakes. (which are s**t)
Standard wheels but i have a set of 14x8-inch meshies with 195/60 front and 235/60 rear that will be on soon.
Roof is bright green, bonnet is black and the rest is white. (colour change soon) have some cool little drawings on the boot and thats about it.
Car only cost me $500 and was bought stock standard so all the work has been done by me as i am a learning panel beater and this is just a car to practice on.
https://www.sau.com.au/forums/topic/353625-hey-guys-and-gals/
haha nice bucket you got there...ah least it's a car you'll learn stuff off that isn't as boring as your stock corolla or excel.
you never know, it might be respectable after you finish the schooling.
Haha cheers mate, and yeah your right on the money there, Corollas and Excels are shit house boring and plain lame.
Lol here's hoping.
It's like someone took the best parts of two cars to make one good car...and then made another car with the other parts :P
Certainly a project on your hands!
Hahaha :)
Yeah it is a bit of a project, but since i am a learning panel beater it will be good for experience. Hopefully within the next couple of weeks it will be Midnight black, the drawings on the boot will be done using a template and will be Monza red and they will fill that whole panel, and i will be making a custom fiberglass front lip unless my mate can find me a cheap kit. :)
Edited by ENR34GT
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
