Whats the specs? and also larger pics and what do you mean by remanufactured?
the specs are inlet A/R is 0.50 outlet is 90 A/R. when i said remanufacted i meant that it has second hand inlet and outlet housings with brand new Center Cartridge, and gaskets. you can come and view the turbo if you want.
Price? Ball bearing?
there are some info on what a garrett GT turbo is, and i'm looking for $950 ono
Improved Turbo Life and Reliability
All Garrett GT-Series turbochargers have the provision for water cooling in the core. Water cooling helps control turbine core temperatures, and prevents oil coking on shut-down. Water cooling has been shown to improve turbo life and reliability.
Ball Bearing Core
Garrett’s patented dual ball-bearing core is the industry standard for ball bearing turbochargers. The Garrett system relies on dual angular-contact bearing races, which eliminate the need for a conventional thrust bearing. A Garrett dual ball-bearing turbocharger is over 4 times stronger in thrust than a journal bearing turbocharger, increasing reliability at high boost levels.
