Hey guys, i had a talk with my brother in-law n i dont mean to sound gay or a di@khead or anythin but my family is very wealthy, n mum is gettin me a R34 GTR when i turn 21........ i know this is a while off still but by the time im 21 the skyline is gon be around 8years old... dont you reckon its a bit 'old' to have around then?
https://www.sau.com.au/forums/topic/35370-your-say/
.....the skyline is gon be around 8years old... dont you reckon its a bit 'old' to have around then?......
How much do you know about quality cars - and classic ones at that and especially SKYLINES to ask such a DUMB question???
Puuhhhllleease
:flamed: :flamed:
dollar to a doughnut it gets wrapped around a tree in less than a week---
:D:) :Bang: :Bang: :):rant:
https://www.sau.com.au/forums/topic/35370-your-say/#findComment-706355
I realise that these forums are open to anyone, but surely you should have whispers of pubic hair before being allowed to join a forum dedicated to turbocharged import cars :D
Oh, and I hope you realise that your parents are just saying "Yeah yeah, whatever" just to get you to shut up and stop nagging them about buying a car the better half of a decade away...
Now go play with your lego set.
https://www.sau.com.au/forums/topic/35370-your-say/#findComment-706598
Aww come on, give the guy a break. If he gets one, great. Wouldn't you have loved a high performance car at that age?
If I were you, at your age I would start getting into Kart racing or that. By the time you are 21 you'll have advanced driving skills and would avoid getting into bad situations. Hell, by the time you are 21 you could be sponsored in some form of motorsport. Then again, if you're Ritchie Rich just get mum to buy you a race team :D
https://www.sau.com.au/forums/topic/35370-your-say/#findComment-706617
Guest
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
