R33 Turbo Stock Airbox with filter & snorkel - $100
R33 Turbo Rubber Turbo Intake Tubing - $80
R33 Standard Exhaust - $60 (has a 3.5" tip or something)
R33 Stock BOV - $40
R33 Series 1 Window Switch - $100
R33 SSSL Front Springs - $70
R33 Series 1 Front Reo (Has been slightly cut) - $30
located in sydenham, victoria. 0433367570
Edited by ROC-HRD
cmon guys need this stuff gone.
Postage Prices
R33 Turbo Stock Airbox with filter & snorkel - $20
R33 Turbo Rubber Turbo Intake Tubing - $20
R33 Standard Exhaust - Pickup Only Or Buyer To Organise Courier
R33 Stock BOV - $10
R33 SSSL Front Springs - $20
R33 Series 1 Front Reo - Pickup Only Or Buyer To Organise Courier
Bump! New Price List:
R33 Turbo Rubber Turbo Intake Tubing - $70
R33 Standard Exhaust - $50 (has a 3.5" tip or something)
R33 Stock BOV - $40
R33 Series 1 Window Switch - $90
R33 SSSL Front Springs - $60
R33 Series 1 Front Reo (Has been slightly cut) - $20
Items That Sell This Week Will Have $5 - $10 Express Postage!
R33 Standard Exhaust - $40 (has a 3.5" tip or something)
R33 Stock BOV - $40
R33 Series 1 Window Switch - $70
Price drop grab a bargain!
R33 Stock BOV - $40
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
