Hey guy's
eoi
my daily ke70
cream
5 spd
4kc
new extractors
new water pump
fairly new radiator
new clutch done 500kms
falcon springs in rear
stock cut in front
interia ok
body on back right ruff and missin a bit of paint
tinted tail lights
near new tyres
has 14inch steel wheels which are polished with sweet off set all round look sweet
reason for sale: currently is runnin ruff and wont idle still driveable been drivin it for a few days like it
$800 will swap for rb20det motor and box package minus turbo and ecu
ns add with pics
call or sms 0439837703
cheerz kenny
https://www.sau.com.au/forums/topic/353747-sa-eoi-ke70/
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
