Hey guys,
Lately my GT-R has been a bit strange.
I will go for a drive and when I arrive wherever I am going and park the car. While it is in neutral the revs are very unstable it will just go up to around 1500 then drop to around 400. It used to be every 3rd day but it is becoming a daily occurrence. Even whilst driving now sometimes when on the throttle it cuts out a little.
I am just trying to figure out what it might be or what it sounds like to you guys.
I just done a major service, I am thinking what to try and replace next. I am thinking of doing coil packs and AFMs
Does anyone have any advice?
Ross
https://www.sau.com.au/forums/topic/353753-r32-gtr-issues/
Had similar symptoms to you.
Cleaned AFM's, sorted all piping for vacuum leaks, ended up being the manifold gasket around 5-6 cylinders that had blown out. Found by spraying brake cleaner around the manifold joints and the idle stabilised.
Replaced gasket with a new nitto metal set. Good luck with that though, painful job.
https://www.sau.com.au/forums/topic/353753-r32-gtr-issues/#findComment-5669507
doubt its a dirty AFM, more likely one on its way out.
exactly what my cars have done in the past with failing AFM.
This. To test turn the car on jump out and give each AFM a shake one at a time, if it begins to hunt after the shake i'd say the joins inside the AFM have worn. Search "soldering AFMs" and there is a DIY on how to do it - fixed my hunting / idle problems.
https://www.sau.com.au/forums/topic/353753-r32-gtr-issues/#findComment-5669718
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
