good afternoon all.
im new to this forum and recently picked up my R33 GTS-T.
anyways i need some advise on how to remove my drivers side door trim as the door will not lock. im not totally stupid about these sort of things but never owned a skyline before and just needed to know if there are some things i should know before i go ahead with it,
any help much appreciated.
cheers, Ben
https://www.sau.com.au/forums/topic/353759-removing-door-trim/
Pretty simple,
Take the screws out from the bottom of the trim
Then there will be a screw at the bottom of the sunken door handle (one that you pull the door shut with) underneath the plastic circle (get that out with a flat blade screwdriver)
Then the tricky part if you havent done it before, is getting the trim surrounding the door handle (the door handle that OPENS the door, not the one to pull the door shut), basically it just pulls off, but its seriously tight, and you WILL think its going to break lol
I used a claw hammer with a rag to lever it off, but make sure you do it from the side to the front of the car.
Then it should just lift off upwards (the top hooks over the door sill)
Unless somebody wants to correct me, im fairly sure thats it :thumbsup:
lol yer well i dunno how to explain it. the actuator wasn't hooked in so i put that back in with a nut of the bottom. it appears to be locking from view but its not actually locking.
spayed a little bit of CRC and it fixed the problem but for how long im not sure.
As far as I know, that's normal with most cars...or at least cars around that era. I know my parently VP Berlina does the same thing, not sure about my R33 though coz my high beams are f**kING PATHETIC while my low beams are blinding lol
ok so i couldnt find anything in search but my headlights... when i switch them to high beam the low beam cuts out?? its this normal? im thinking its not meant to happen,, any advise?
Yes that is right. Low beam and high beam work independently of each other. Theres a tutorial here somewhere that tells you how to make them both work with high beam but
As for your locking problem.... Do you mean the door lock tab in the trim moves as if to indicate it's locked but the door still opens? If so pull the latch off and see if everythings all good in there
  • 4 years later...
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
