  • Replies 96
great day out! the old girl ran well and i had an absolute ball.
for the first time i felt the need for a turbo to push me along the top end of the straight a little more...
and maybe for some grunt to pull me out of corners in 3rd so i didnt have to go back to 2nd every corner...
anyone who crossed paths with me on the track ive probably got some footage of you from my in car vid..
let me know if your interested in seeing it...
yeah i had the camera on, unfortunately the flames i told you about were just out of the camera angle (i saw the flames as you were passing me but you werent quite in front in the camera view yet)
but i did catch you finding some dirt turning onto the main straight :nyaanyaa:
i was in group 3 driving the green datto ute
Awesome day out weather was sunny all day, pretty happy with how the car ran first time out. I managed a 1.11.18 best time, with hitting the speed limiter about 4 times before breaking for turn1 lol Im sure i could have shaved a few seconds there, car is also not running any boost, ecu or clutch about 170kw atw.. my guess. I deff need to invest in a oil cooler, i have never seen the gauge go so high lol and the car was drinking nearly a quarter tank every 6-7 laps i went and put another $30 at lunch and chewed that too got heaps of laps in and ended the day a session or 2 early.
Best part of the day was the battle i had with billy blags took me 4 laps to catch him and pass when he oversteered haha :yes:
p.s thanks for the pics they look great
yeah even with the smaller engine I had to call it quits. had the fuel pump scavange thought a couple corners so I had to pull in.
Seems 1/4 tank the lowest I can go. Might start dragging a extra fuel can with me from here in.
i had a prick of a day. on my first fast lap on turn one my brakes failed. i didnt brake very late. started at the 300m make and still ended missing the turn. lucky they have abit of runoff room. front left bleed nipple was leaking and it was tight. so we pulled it out to see if it was damaged. but it looked good so we changed the nipple anyway and bled the brakes. it lasted a few more laps then started leaking again.
your brakes were smoking alot when i was following you... looked like you cooked them nicely at the end of the straight. did you bed your pads in properly?
Awesome day out weather was sunny all day, pretty happy with how the car ran first time out. I managed a 1.11.18 best time, with hitting the speed limiter about 4 times before breaking for turn1 lol Im sure i could have shaved a few seconds there, car is also not running any boost, ecu or clutch about 170kw atw.. my guess. I deff need to invest in a oil cooler..........
Well get on the power then, nistune, boost 't and away you go cheers.gif.
Oil cooler is a serious must if you want the engine to last and save money as the oil will be shagged now. 2 hot laps and I was cooling down (didn't have time to fit the cooler on the car), then hit it up for 1-2 more hot laps after the cool down lap.
yes i bedded them in and they were working great before i took it to calder. they didnt over heat. i cant get any pressure on them.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
