Just looking for some help on choosing a suspension setup for my R34 25GT-T, I've been told that alot of kits are so poorly designed that they have ended up snaping, so am looking for past experiences with different setups.
List me some brands and prices and what your experience with these setups has been like.
Thanks Jared.
https://www.sau.com.au/forums/topic/353861-suspension-help/
I will make this one easy for you from my experiences
Street - A bilstein set up if you don' t like coilovers with height adjustment, TEIN SS's latest model will be very nice and a very comfortable ride indeed, BC BR's or RS's if you want a reasonably firm ride with good adjustment!
I have had all of the above in my 34 sedan, all are and have been a great set up, currently running my new BR RS's from BC, love em and really transfers the weight well, a little soft for hardcore track work but nice enuf.
Drift/Track work- Go for a coilover with higher spring rates 10/8kg or more if you like it ruff. HSD would be good value for money here.
Hpoe this helps!
https://www.sau.com.au/forums/topic/353861-suspension-help/#findComment-5674158
Hpoe this helps!
Thanks for the replys, im leaning towards coilovers atm. I just wanna lower my car close to 2 inches.
Currently getting new camber and bushes installed.
And will most likely get some whiteline swaybars.
Just stumped on coilover choice, anyone got some prices for me - new and 2nd hand would be nice.
Cheers Jared.
https://www.sau.com.au/forums/topic/353861-suspension-help/#findComment-5675807
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
