Well given he's done "a few hard laps at the track" I'd say somehow the oil was still managing to flow throughout the motor. Even 5 minutes of driving would completely ruin the engine...
Yeah I'd check it.
I had a thermostat on the oil lines that bypassed my oil cooler if oil wasn't hot however it didnt flow well enough and I ended up with a spun bearing.
Can always try bypassing the cooler by removing the cooler in hose and looping straight to the engine to see if it makes a difference to the low oil pressure you mentioned.
im hoping it was all ok... i still had plenty oil pressure when running the motor etc. so i guess the pressure valves must have popped. lucky i'd say
is having the oil coolers inlet and outlet on the bottom a bad idea?
Depends on what kind of cooler it is. With some designs it will not fill properly from the bottom.. If you turn it on its side and have entry at the bottom that will be ok or have the inlet and outlet at the top.
not sure mate but putting 2 in the pink and 1 in the stink isnt a great idea, u'll get shit on your pinky, better off putting 3 in the pink
  • Like 1
  • Nope 1
oil analysis, its like $50 and mainlube.com.au do them, highly recommended, will tell you if you have shagged the bearings or anything.
this is something you want to find out now before catastrophic failure, it could be fine though.
+1 for oil analysis ..at least you know exactly what condition your bearings are like.
Or just keep punishing the engine as you normally would ..you will find out soon enough if its good or if its f*cked.rolleyes.gif
Some oil "should" have gone through the over pressure bypass built into the factory oil warmer, if you have removed that or a running an RB20 one you will be in trouble
This pressure bypass is all that kept my engine running. My engine still ran fine, no rattles or any bad noise. It was just all the metal in the oil that worried me. It wasnt worth the risk to fix the lines and keep running the car so I had it pulled down.
nah i wouldnt say full. i drained the oil into a clean bottle that wasnt black, cut the side out of it. then poured it into a waste drum and left a bit in there. holding it in the sun reveals the oil to have a metalic sparkle to it. and then right at the bottom was a couple of tiny metal flakes.
so yeah.. pretty clear damage has been done.
bummer. sorry to hear that mate. :( yeah if the oil has that nice metal film and some sparkle to it chances are that's your bearing coating in there. what a bugger.
did an oil change today.... and well... not the best result :(
dont think i'll need to send an oil sample off. that will be 50 i can put towards a new motor i think
Hope your result isnt as bad as mine.
My oil looked like mercury with lots of chunks of bearings lol
Edited by WHITER33GTS-T
nah mines not that bad. have spoken with a few engine builders and they have all said it looks like the start of some bearing wear and that placing a life span on it is impossible.. could last a day could keep going for another 12 months. Gonna start building a spare bottom end i have anyway i reckon!
sorry to hear that.
if it has picked up some bearing already, pull the motor. it only gets more expensive (more needs replacing) the longer you run it.
I would know, I've done it often enough lol. My record for a motor with incorrect oiling was 50klm from new to bearing spun
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
