Well given he's done "a few hard laps at the track" I'd say somehow the oil was still managing to flow throughout the motor. Even 5 minutes of driving would completely ruin the engine...
Yeah I'd check it.
I had a thermostat on the oil lines that bypassed my oil cooler if oil wasn't hot however it didnt flow well enough and I ended up with a spun bearing.
Can always try bypassing the cooler by removing the cooler in hose and looping straight to the engine to see if it makes a difference to the low oil pressure you mentioned.
im hoping it was all ok... i still had plenty oil pressure when running the motor etc. so i guess the pressure valves must have popped. lucky i'd say
is having the oil coolers inlet and outlet on the bottom a bad idea?
Depends on what kind of cooler it is. With some designs it will not fill properly from the bottom.. If you turn it on its side and have entry at the bottom that will be ok or have the inlet and outlet at the top.
not sure mate but putting 2 in the pink and 1 in the stink isnt a great idea, u'll get shit on your pinky, better off putting 3 in the pink
  • Like 1
  • Nope 1
oil analysis, its like $50 and mainlube.com.au do them, highly recommended, will tell you if you have shagged the bearings or anything.
this is something you want to find out now before catastrophic failure, it could be fine though.
+1 for oil analysis ..at least you know exactly what condition your bearings are like.
Or just keep punishing the engine as you normally would ..you will find out soon enough if its good or if its f*cked.rolleyes.gif
Some oil "should" have gone through the over pressure bypass built into the factory oil warmer, if you have removed that or a running an RB20 one you will be in trouble
This pressure bypass is all that kept my engine running. My engine still ran fine, no rattles or any bad noise. It was just all the metal in the oil that worried me. It wasnt worth the risk to fix the lines and keep running the car so I had it pulled down.
nah i wouldnt say full. i drained the oil into a clean bottle that wasnt black, cut the side out of it. then poured it into a waste drum and left a bit in there. holding it in the sun reveals the oil to have a metalic sparkle to it. and then right at the bottom was a couple of tiny metal flakes.
so yeah.. pretty clear damage has been done.
bummer. sorry to hear that mate. :( yeah if the oil has that nice metal film and some sparkle to it chances are that's your bearing coating in there. what a bugger.
did an oil change today.... and well... not the best result :(
dont think i'll need to send an oil sample off. that will be 50 i can put towards a new motor i think
Hope your result isnt as bad as mine.
My oil looked like mercury with lots of chunks of bearings lol
Edited by WHITER33GTS-T
nah mines not that bad. have spoken with a few engine builders and they have all said it looks like the start of some bearing wear and that placing a life span on it is impossible.. could last a day could keep going for another 12 months. Gonna start building a spare bottom end i have anyway i reckon!
sorry to hear that.
if it has picked up some bearing already, pull the motor. it only gets more expensive (more needs replacing) the longer you run it.
I would know, I've done it often enough lol. My record for a motor with incorrect oiling was 50klm from new to bearing spun
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
