Hey all,
This is a topic that hasnt been covered much for the guys upwards of 400kw that I could see.
Here's the issue;
On my GTR i have the ARC airbox with twin genuine ARC filters. Give it a squirt of full throttle and the filter gets sucked in to the actual airbox and all mangled up into a mess ($110 each, this gets tiresome quickly). It was funny the first time, but now its just plain old annoying.
This problem rose its head somewhere between 380 and 403rwkw, so im confident in saying that the limit of the (completely unmodified) ARC box is somewhere in there for at least my setup. Note; ARC dont seem to list a max HP/KW for this box
Now given that im past 403rwkw, something has to happen here as its annoying but not only that im sure its a big restriction on power if its strong enough to suck the filter in (which has allen keys on the filter bracket).
So far ive come up with;
1. Mod the ARC box with more bracing for the filters (not keen on that, its too nice as it is and the restriction will still be there)
2. Get a stock airbox and mod that but who knows how that will turn out
3. Something made from scratch using high flow commodore/falcon filters locally available and with huge surface area and filter braces
4. Use pod filters (no fkn way)
I know this thread wont apply to everyone just like the GT-RS on stroker motor thread, but id love to hear what anyone with a 400kw plus GTR has to say on the topic so please speak up :D
.....aaaaaaaand go!
https://www.sau.com.au/forums/topic/353896-gtr-airboxes-for-large-hp/
  • Replies 42
Steve after looking at ur airbox yesterday its a pretty poor design how they have the top filter just sitting in there. It needs to have a lip underneath the filter not just on top. If u fitted an underside lip and also a thin t bar crossing underneath also it will fix ur issue and not create any flow restriction
My ARC airbox had exactly the same problem ..but i was using a K&N filter instead of an arc one, which i assume was slightly different in size.
My fix was just what DVS23R mentioned as well..i tigged a cross under the filter out of 3mm diameter stainless rod..problem fixed
Although now i have gone back to a modified factory airbox because i prefer the stock look.
FG XR8 Airbox and snorkel with K & N panel filter fitted to FG F6 turbo.
Good for tad over 500rwhp....maybe more. http://forum.rdpbris...ic.php?f=4&t=80
Given the long intake tract to the other side of the engine bay in a stock F6 I dare say it would be more efficient with shorter inlet tract in a GTR .
Also being plastic - less heat soak.
Can be modded to fit a pod filter inside.
I have one of these at home......so if you want dimensions just ask.
My 2 cents.
Edited by juggernaut1
or if your really adventurous ...the factory pod filter setup in the new Coyote supercharged Fords could possibly be made to fit?
http://www.caradvice.com.au/85953/fpv-gt-gt-e-gt-p-gs-supercharged-coyote-v8-review/
from the pictures that the first version of the arc box which ran the paper filters with the steel housing(no suck in).
the type 1 box and type 2 filters which dont have the support is what is happening with your box
the arc airbox can be modded fairly easily to stop that happening and wont cause any restrictions/flow loss.
Tangomatt - 410rwkw stock airbox, nismo intake
Aaron34 - 400rwkw stock airbox
:D
Was any back to back testing done to come to that decision? Genuine question I.e. Comparison with Greddy hard pipe kit?
Come to what decision? Those were the results.
As for comparo, perhaps @ some point on someone else's car. Can't say without question but then who can say they've tested every off-shelf airbox on the market? :)
Tangomatt - Using the Nismo intake kit going by the pictures (piping included). Just not 100% on the actual airbox itself.
Aaron34 - factory R34 GTR far as i know
The decision to use the standard airbox over a suction kit.
Not for every one just this... surely someone has done a power run make "x" KW then taken airbox off replaced it with pods or a full suction kit and made "y" KW?
I would be happy to use the OEM airbox with a Nismo snorkel and replacement AFM pipes knowing that it would not be a restiction.
well given the two cars do have some different items...
vcam, piping, snorkel... but are pretty much the same output... its a good representation.
also the airbox vs pod, maybe but how do you test that on a dyno with excessive heat soak that the airbox will not suffer from in bonnet down test over time. pod will always suffer :(
not running 400rwkw but when I tested the R32 GTR box back to back with Blitz pods at 280 rwkw I lost about 20 rwkw. put the box back in, took the lid off and taped the panel filter in and the power came back. not consistent with the experience of others and both tests were done with bonnet up, but it's a big difference either way. front of box is now modified but haven't done back to back test with it in that config.
Chopped part of the bottom of the 32GTR airbox out to get more flow, I was running only 363RWKW though.
Didn't like how small the single inlet at the front was. I was running 80mm Z32 MAFs on the stock box too.
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
