This '05 MX-5 has been vinyl-wrapped with carbon fibre vinyl.
Swaps for other manual sports RWD cars (+ or - upto $10,000 cash adjustment) are also considered.
A State Road vehicle inspection report was conducted March '10 to document the condition of the complete car before the wrap. This report covers all aspects including body, mechanicals, interior and any evidence of previous repairs. The report confirms an excellent condition with no previous accident repairs. This report can be emailed upon request. The vehicle has travelled under 5,000km since the report was conducted.
Log book, owner's manual, 2x original keys & MX-5 tailored mats are included.
Modifications include:
Wrap by Carbon Demon ,
Tein Flex coilover suspension (purchased in April '10 with receipts) ,
UL chassis braces x4 ,
Enkei 17" rims (no scratches) ,
ADR-approved Autotechnica buckets (factory leather seats are included and in excellent condition) ,
K&N panel filter ,
Eclipse TomTom head unit with stock BOSE speaker/amplifier retained. SAT-NAV/USB/Bluetooth/MP3/CD/radio functions. Works with iPhone and others. ,
Alloy wheel lock nuts
Other than the stock rims, ALL standard parts are included. Vinyl wrap is FULLY reversible.
This car is fully road legal. Its finish is approved/recorded by the RTA.
Please call: 0425147515
To email Mike: [email protected]
Edited by Carbon Demon
https://www.sau.com.au/forums/topic/353903-mx-5-nc-05-for-sale-or-swap/
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
