I think that was a legitimate speed camera flash because it seemed to come from the other side of the intersection? Then again, I don't remember another flash and my car is in this photo :/
Speed camera flashes have traumatised me for life.
If that's your 32 Jamie, it dumps quite a bit of smoke when you're giving it stick!
:laugh:
Mr. Windsurf (Andrew) said the same thing... O2 Sensors might need changing again.
Does it use the O2 sensor when you're full throttle? Could be too thin an oil or worn piston rings / turbo seals. Can't remember if black smoke is oil or fuel burning.
whitey blueish smoke is oil...
black is rich fueling...afaik
btw, how bad is mine? I have never checked other then in rear view... just with the screamer I can't imagine it would be much better?
Yeah, Andrew said the same thing, black.
Must be running rich.
Adam, yours blows a fair bit under load, but every car will do something on full throttle...I don't remember noticing anything as much as I did Jamie's. Sounds like you do need a tune Jamie :)
Nar you'll have to Nistune or PowerFC for a dyno tune...but I meant "tuning" as in getting everything running right. You might actually have an underlying issue as to why it's running rich under load. On light throtle / cruising it's usually an O2 sensor...but this might be injector, spark or timing related? Nothing to be concerned about unless it's fouling your spark plugs, it'll just use more fuel and might not be as powerful as it could be if it was running leaner :)
Guest
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
