Hi all was driving home work tonight cruising along and my S1 25g with stock N/A RB25de started to run very sluggish s0o pull over switch her off but she will not start, got power, faul pump and starter goes got comprestion,inject pulse and spark but wont start.
Thinking maybe has jumped a tooth in the timing???
Can anyone please help
Cheers
Edited by 17yostagea
https://www.sau.com.au/forums/topic/353943-stagea-brake-down/
im apprentices mechanic so call my boss out at 8:30pm out with the plugs in to test for spark and pules
got it towed to work today took off the coveres and there just bit of timing belt everywhere and jumped about 6 teeth just peeled the top half off the teeth in belt il get pics tomorrow
Fingers crossed no real damage
right....well then you already know it is likely to be bad then.
the only rb know for sure is non interferance is rb20. if rb25det is interferance and rb25de has higher compression....it is very unlikely to be OK.
Come on Duncan don't be a spoil sport, I am pretty sure JP showed you the timing belt that came off my R33 when the idler bearing seized and stripped the timing belt.
New belt fitted, it started and purred like a kitten. :banana:
I have no chance of winning Powerball now. :no:
yeah 25det and 26dett definately are interferance. Not really surprised rb30e is non, I wonder what a hybrid rb30det is, pretty likely it will be interferance?
Andrew....damn straight you have used up all your luck! I broke a cam a few years back, that was carnage for valves and pistons :(
could be onto something there iv got a new belt to fit tomoz what esle u do to it just the belt?? and away u went?
The mechanics expected they were going to take the head off but figured it was worth trying to fit a belt and idler bearings and then turn it over by hand to see what would happen. It turned ok, so they cranked it and it started like normal.
There is no joy in getting the bill for a new timing belt (etc) but in this case it beats the hell out of a new engine.
I have seen teeth stripped off the belt before and every time the belt had been subjected to engine oil leaking on it. Look for oil leaks and check bearings I would like to know what caused the belt to break.
Should know today
$360 from nissan, is it possible to get second hand?
Our local bloke got a full reco set, both pulleys and belt for $225. :banana:
Edited by 66yostagea
