Are you serious Brah?
That's about as ambiguous as asking how long is a piece of string... Lol, how do you expect us to know how your car's running if you havnt told us anything about it? Haha
Turbo? Exhaust? Intercooler? Engine management? Any other mods?
13psi and only, 240hp, I'd say there's something wrong, or your car is bog stock.
https://www.sau.com.au/forums/topic/353953-my-dyno-run/#findComment-5670698
Its Ovaboost - dyno reads rediculously low. My RB30DET made 320rwhp on that dyno @ 17psi (big auto), but still managed to run an 11.7 with a 2.2 60 foot time. I wouldnt be too worried about the number (assuming its a relatively stock motor). Mick is an awesome tuner.
https://www.sau.com.au/forums/topic/353953-my-dyno-run/#findComment-5671388
if their dyno does read low then that sounds about right man.
now im on 275rwhp at autoworx on 12 -> 10 psi (12 then drops to 10), stock turbo/ injectors, fmic, full turbo-back exhaust, pod filter, vi-pec v44, walbro fuel pump.
i still gotta get rid of that gts25-t sticker on the back, to release an extra 10rwhp..
https://www.sau.com.au/forums/topic/353953-my-dyno-run/#findComment-5672233
I'm pushing 260 ish rwhp in my 350zee
and my old r33 skyline r33 made 278rwhp at 13psi with just a 3 1/2 cat back and intercooler
but the standard 7psi sounds pretty good!
not bad for a 3.5na
mods ?
240-280rwhp is pretty good for a std turbo stock ecu car with the usual bolt on mods
https://www.sau.com.au/forums/topic/353953-my-dyno-run/#findComment-5673920
ok so does that mean i should go somewhere else to get another run?
https://www.sau.com.au/forums/topic/353953-my-dyno-run/#findComment-5674385
Means you shouldn't read too much into it, the number is just a number. My car has been on 4 different dynos and gotten hugely different numbers every time. It's a tool for tuning, for comparative purposes they are inaccurate at best.
https://www.sau.com.au/forums/topic/353953-my-dyno-run/#findComment-5674399
Cough 200rwhp RB25DE
:rofl:
https://www.sau.com.au/forums/topic/353953-my-dyno-run/#findComment-5674407
Dont get too carried away with a dyno number leave that for the big block boys who can't turn corners...
you can have 1000hp if you like, just to say how 'cool' you are but end of the day i bet on a street road to 100km/h a 300hp car would chomp it due to getting the power down and response of the engine....
the dyno is a rolling road for tunning and no more than that
https://www.sau.com.au/forums/topic/353953-my-dyno-run/#findComment-5675059
ovaboost are great tuners, and they themselves told me last week when i went to check on my cars progress that their dyno is known as a 'lowish reading' dyno.
i've got a great idea for u tho, if u want to pull all the 14yo chicks with ur hectic stock skyline, go find yourself a place that uses a dyna pack.
it sure helps all the dumbass's in NZ pull 1000rwhp from a turbo rated at 700hp
https://www.sau.com.au/forums/topic/353953-my-dyno-run/#findComment-5683175
BTW mods are front mount, full 3 inch exaughst (not including dump),044 fuel pump, duel port turbosmart Bov, super spark coils, ngks gapped to .08, k&n pod, cai, gizzmo 6 stage boost controller. Running bp 98
https://www.sau.com.au/forums/topic/353953-my-dyno-run/#findComment-5684377
Dumbass' in NZ? Haha, in six years in WA I have seen more idiots on the road, more accidents, more prangs, more wrecks and cars dumped on the road than 19 years of living in NZ. Mind you, the Import seen is alot larger in NZ, so maybe it's a numbers game?
https://www.sau.com.au/forums/topic/353953-my-dyno-run/#findComment-5684765
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
