Please no time wasters and low baller !
Please only contact if you are genuinely interested and have the money ready!
19" Bronze TE37
INGS bodykit full bumper front,rear,side
Bridgestone RE-01R Tires -
Tein Monoflex Coilover
Nismo Sway Bar Front and Rear
Tomei Expreme Headers
HKS True Dual Hi Power Ti Exhaust (US)
C's Short Shifter Kit
06+ Rear LED Lights
HID Kit
Greddy Air Diversion Plate
Nismo Gear Knob,
ARC Radiator Cap,
Greddy Engine Oil Cap,
DVD/MP3/USB/TV Player,
S2K Short Antenna,
Tints etc
NOT LOOKING FOR SWAP OR WRECK THE BITS!!!
ONLY AFTER SALE NO SWAP,AND ETC.
CHEERS!!
PRICE:40K ONO
2003 Nissan 350Z touring
50xxxx kms
CURRENTLY OUT OF TOWN CONTACT ME VIA EMAIL: [email protected]
https://www.sau.com.au/forums/topic/353956-350z/
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
