To name a few
Mazda 3 MPS
Nissan Maxima
Mazda 6
Honda Accord
Holden Statesman
Lots of others
But I cheated. My dad is a surveillance cop so he has a new car for wwork every few months. hehe.
He doesnt pull anyone over or do any kind of traffic work. in fact he hates them. Taught me the term 'concrete dickheads' from when i was about 5 years old
  • Replies 46
I work near the main police officer and there is heaps of cars that are police cars but 90% of them are not TMU or anything like that
and it sounds like some people are listing speed cameras there not police vehicles there sub contractors
img]http://www.muamat.com/adpics/4bf74fb375c913af78812e58c.jpeg[/img]
One of these.
One of these.
And a KE70
I think they pulled the last two from lockups or something.
Also heard of unmarked FPVs and HSVs trying to gee up drivers.
now that one is a shocker!
i had no idea it was anything other then a new como with 3 rear antennas and a territory
Mate the Territorys are everywhere lol.
There was actually one time on the M1 freeway from north heading to SE suburbs. A policeman was taking speeds of drivers right at the merging lanes but on the zebra zone. Found that quite odd.
I agree they're everywhere. But it was the only turbo territory that I've seen so far.
I have seen a totally unmarked, undercover police Hiace van.
Was filling up at a petrol station, on one of my country runs, saw a policeman walk out of the shop. Thought to myself; "i didn't notice a cop car around", he then jumped into a plain white Hiace van. It even had the small blue and red lights in the grill.
Quite often see the VW Transporter van around Williamstown (it seems to live at the local station) Its a Transporter 4Motion, whatever the kick arse engine they can get type.
It's white, with black roof rack, but looks to clean and undamaged to be a tradies van
Lights are behind one of the blacked out rear windows.
I only know it's a cop van as I saw it going down the freeway qith the lights on.
Saw a Soccer Mums SUV pulled over on the Calder Fwy just outside Kyneton at the start of summer with the bonnet up, baby on board sign on the back window and hazards on. Like the lovely person I am (although running late for work) I stopped, expecting some mum and bub had over heated on the way to Melbourne....only to find it was Mr Plod (I realised this as I got out of the car and noticed the HUGE camera plate over the bull bar)
I felt as if my good nature had abused...and they wonder why people don't stop to help others
That may have been a forensics van.
The cops used to do that around the Yarra Valley, park a beater that they had gotten from the wreckers at the side of the road on a jack with a wheel off, making it look like a breakdown, until you went past and saw the camera. They stopped doing it after the local rag exposed it and proved that it was against the rules at the time.
saw a light blue XR6T pulling burnouts and drag racing people. got about 5 minutes down the road to see him pull over a datto. it had flashing lights inside the rear door handles as well as behind the mesh on the front bar.
these people egg them on n then pull them over?
A friends mum does that for a living (being a sub contractor) she uses a beaten up late 80's land cruiser that barely goes......and she gets paid a mint for doing it
    • Welcome.  800hp should be a bit of weekend fun!
    • I'm going with "Just run two gates". Fix the problem conclusively. It's the only way you'd ever truly know, right?. This is all pretty much splitting hairs. Even the extreme example where it takes two whole seconds at 100kmh or something sounds monstrously dubious. And anyway, when you're punching the throttle when you 'need' this power, you aren't at 2800rpm in the wrong gear. Test it at 5600rpm in 3rd gear, when you're traction limited punching out of a sweeper. Much difference there when you account for traction?
    • And the full R32 GTR wiring diagrams are also freely available. Hmm.... there's supposed to be an auto replace that would have linked the thread. Here it is, manually
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
