MUST BE SOLD THIS MONTH!! OR WRECKING! Over it. Want it gone. Also up on EBay so be quick, Bargain of a lifetime.
Engine:
RB26
T04R Single Turbo kit
Stainless Manifold,
60mm Tial Wastegate
Tomei 260 Poncams
Tomei adjustable cam gears
Sard 700cc Injectors
Sard 280ltr Fuel Pump.
Gates timing belt.
New gaskets.
Braided fuel lines.
Vipec V44 programmable ECU with Map sensor
Suspension:
Tein Mono-flex fully adjustable coilovers
Cusco front and rear strut braces.
Driveline:
Stock 5 speed,
Nismo short shifter.
Brakes:
R33 GTR Brembos calipers all round.
DBA slotted rotors.
R33 GTR ABS unit.
Wheels:Not sold with wheels pictured, currently on space savers.
Interior:
Recaro SR reclinable drivers seat.
Jaycar speakers all round
Nismo 320km Cluster
2/4wd Switch.
Turbo timer
EXHAUST:
4" Veilside exhaust from Turbo back. With 2 centre mufflers (quiet)
Exterior:
Customised Full genuine Bee-R (B324r) Widebodykit with R34 gtr front end.
Satin Black respray (nothing special used to be purple)
R34 Xenon headlights
Sparco alloy fuel cap.
Car has made 308awkw's on 15psi on a conservative tune.
Car Needs new clutch as current one is undrivable (slipping) Can supply Exedy triple plate for $800 extra.
Interior is in good condition,
Car has no rust, non accident.
Engine drives nice and strong and quiet, serviced every 4-5000kms using Castrol 0-40 regardless if driven or not.
Could do with a clean up, paintjob is abit rough, and a few stress cracks in the rear guards and window seals could do with a changing.
Looking for a quick sale. Not negotiable. Easily cheapest GTR on the market with these mods. May swap for lexus, Maxima Ti, Mercedes, BMW, Audi. (any luxury 4 door auto for the missus)
My loss your gain. Spent over 20k on top of car purchase price. I'm sure i could strip car and sell parts separately but can't be bothered. Nothing wrong with this car, needs a cleanup and clutch installed and its good to go. Was formerly a showcar and was painted purple but decided to make the car more of a sleeper due to ever increasing police presence but have lost interest as i didn't drive it much and because of other projects.
Car is complied and was previously registered.
Car sold as is, no rego, no rwc Inspections welcome and preferred.
Located in Melbourne. PM or email me on: [email protected] for any details etc.
Click on link below for pics (note in pics car is missing tail lights and mirrors as they were getting painted, they are inlcuded in sale) Car is also, dirty/wet in photo's.
GTR pics
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
