Hi,
Searched for a while, didn't get anything i was after.
Just wondering if Brisbane guys could point me in the direction of some sub builders. I've recently purchased a complete system, but need someone to build a sub enclosure to fit in the boot of my 32GTR, i'll also be needing someone to install the system as well as i'd prefer it to be professionally done.
Any help is appreciated.
I work west of Brissy near Ipswich but it doesn't need to be near there.
Thanks
https://www.sau.com.au/forums/topic/354048-sub-enclosure/
Sim
If your after a top job it'd have to be Chris @ http://www.audioexpress.com.au/.
brilliant with stezaz, & knows skylines
check out his 32. Speaks 4 itsself!
Bundy
Thanks Bundy- I spoke to Chris as i saw a link to him while searching, however he doesn't build subs!
https://www.sau.com.au/forums/topic/354048-sub-enclosure/#findComment-5673246
Simon
bugga, can't recomend anyone else, bee'n 900K away and hav'n a habit of not recomending anyone I couldn't learn from, I'm out
Someone in brizzy gata have had a box build latley!! ......bump
bundy
https://www.sau.com.au/forums/topic/354048-sub-enclosure/#findComment-5677597
I got mine from seductive.sounds on ebay. There pretty good quality and mine fits really well.
Seductive.Sounds Ebay Link
The R32 sub is not listed on there but the R33 one wasnt listed and I just messaged him and he said that he could make it, Think he has alot of unlisted boxes he can make, might be worth a try anyway... Shipping on it wasnt that expensive
https://www.sau.com.au/forums/topic/354048-sub-enclosure/#findComment-5695954
Generic box = generic sound
https://www.sau.com.au/forums/topic/354048-sub-enclosure/#findComment-5697224
Yeah if your just making a plain box definately give it a go at making it yourself if you have the tools. Should only cost you around $30-$40 for the supplies, little bit more for some carpet. If your not happy with it you can try again or get a pro to do it :P
I used this site to get the measurements for my enclosure and it sounded good to me and I eventually sold it to another person and they though it was a box bought from a store :)
Good for L ported designs.
http://www.reaudio.c...t_Box_Calc.html
Edited by S4LVA
https://www.sau.com.au/forums/topic/354048-sub-enclosure/#findComment-5699714
Hey Mate
If ya gona build your own start by contacting the manafacturer of the sub, and getting the 'recomended' Enclosure specs, depending on the sub youll get specs for sealed &/or ported &/or x order bandpass's.
These realy are the best box for the sub (the Manaf have a huge R&D budget and know the sub betta than anyone).
If your into soundsystems and know what Exactly what sound your after then use the 'recomended' as a starting point.
as for the link above, those box specs ARE TO SUIT REAUDIO SUBS, if you have another brand these specs are useless. you'll need the Theil/Small peramaters of the sub, before you can start to design a custom box (not 4 the faint hearted).
Best and easiest way, call the manafacturer, get their sujested box sizes. If you want loud bass build a ported box, if ya want good sounding bass build a sealed box. Given you said you wanted to free up boot space I'd sujest the ported box cause their usually smaller.
https://www.sau.com.au/forums/topic/354048-sub-enclosure/#findComment-5699737
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
