wheres a good place to get a nistune? im surprised no one mentioned injectors..or is that pointless untill hunting done more power in the future?
sorry guys i only asked for a stupid number like 5 mods cause of budget limits :(
p.s if i were to set my boost at 10psi(stock turbo/r34 gtt smic) would a boost T do the job?
thanks for the feed back so far guys
Injectors would be like number 6, along with fuel pump. The others mentioned are the mods to start with because without those injectors are pointless. Why would you need them without the extra power/need for fuel?Yes a Boost T would do fine.Just do some searching on this forum, you'll find endless threads about reputable workshops, what mods to do first, what gains to expect, info about ECU's etc.
1. put a built RB30 bottom end on
2. build head/cams
3. put a correctly sized turbo on
4. injectors
5. OIL
Thats on the mota, then the ECU, then the fueling, then the tune, then the drivetrain, then the suspension, then the brakes, then the tyres, then the cooling (i/c oil cai)
And then, and then, and then
Welcome my friend.
iv come to realise that the mods never end do they haha
yeah i might leave the injectors later once im keen on more power but i might just boost to 10psi and get some new spark plugs
once iv boosted should i get a tune done or not really needed??
ok, cheapest decent power available: :)
1: gcg highflowed turbo - 2nd hand - $1000
2: turbo back exhaust - jjr or similar - $1000
3: turbotech (not turbo smart) boost tee - $50
4: china spec fmic & piping kit - $300
5: nistune - $800
6: clutch - exedy single plate button $500
7: diff - welded - $100
ok, so for $3750 or thereabouts you can have ~ 230rwkw and a fun car to drive. add coilovers for around 5 grand that's pretty sweet.
injectors, z32 afm and fuel pump could be added to this later on for around $1500 and you will have ~260rwkw
  • Like 1
For the fully sick individuals:
1) paint brake calipers red (+25rwkw)
2) flower stickers on rear window (+5rwkw per sticker)
3) fake turbo noise clip-on for exhaust (+50rwkw)
4) Neons (+35 rwkw per item)
5) 22" China spec chrome dinner plate rims (+90rwkw per wheel)
Or
Sell the car & buy a Hyundai Excel, do the above mods to it for the instant over 9000kw
For the normal people:
1) turbo back exhaust + high flow CAT
2) high flow panel filter + stock air box or POD with enclosure
3) Intercooler upgrade
4) Boost controller (manual or electronic)
5) Some sort of engine management + tune
Edited by Mayuri Krab
5: nistune - $800
this sounds goood, since im on a cheapish budget...but i might get a jap intercooler since iv heard alot of people complain with the chinese ones.
quick question whats the pros and cons of getting my cat high flowed??
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
