where do yoou guys get your stage m35 plenum spacers from?
do you notice much gains from them ?
We made them... all ours are sold but I think "IAMHE77" has some left in Melbourne.
Gains are slightly more power off boost and better economy when cruising. The difference in intake temps is worth the effort.
