Hi All,
As of the majority of us DIY our services on our cars Im curious as to what method everyone uses to know when they have changed/replaced things. Sure oil and filter is a pretty easy one to remember as its at every 5th thousand for most of us... More curious as to how every one records when they change fuel filters, 02 sensors, longer lasting oils than engine ect ect....
Ive got into a habit of if the item comes with a sticker saying when to change it next or when it was installed and putting it in the fuse box under the ignition, how ever not all things come with these.
Cheers,
Chris
Yeah, I normally write date & km on a visible area or sticker.
I started doing it a few years ago cos I had four cars & 2 motorbikes; its just too hard to remember otherwise. I also have a book with kays for tyre rotation, suspension and alignment settings.The m35 has service warnings in the pop up screen, so I use those for air, oil, gearbox and tyre rotation.
Edited by Daleo
I had a little book that I pasted in a typed sheet for any "event", be it an oil change, tune or even wheel alignment.
Did this on a 4 door R33 that I had back in the 90's, before every ricer had one (no offense to anyone who may have one now). It was only 2 years old when I got it(20K kms) and more expensive than the M35, even tho it was a SUTI vehicle for my impoter, so I wanted to keep good records.
When I sold it years later at the same import place, amongst a whole yard full of really nice cars, it was the log book that sealed the deal! I'd recommend it to anyone.
i write mine down on the sticker and put it in the log books - but also keep an excel spreadsheet of every cent i spent on the car, from mods to maintenance (replace or repair) to consumables (plugs, oils, fluids etc).
i find this to be hugely helpful. i have done it on all my cars and come sale time, it really helps you as an owner to have a true understanding of what the car owes you, but also to demonstrate to a buyer what has gone into the car beyond the purchase price (which is usually the market price).
for anyone more tech savvy though, there are apps available for the iphone for recording all this info :thumbsup:
  • Like 1
when the 4th last digit on the ODO is a 5 - dump oil and put in new
when its a 0 change filter and dump oil replace etc
5000km oil changes 10000km filter changes
easier to remember this way
+1
:thumbsup:
I do all my own work, and its not too hard to remember. I even schedule in removing the turbo and inspecting its condition every 20,000kms amongst other things :P
And every 6 months (tax time and xmas time) I inspect the engine bay for the obvious and not-so-obvious leaks, and get the car up on the hoist to check underneath.
:thumbsup:
Exactly what I was after and purchased one this morning :-)
I dont see the point in not doing the filter and the oil at the same time, they cost 7 dollars or something stupid why not spend it.
So when you change all the little bits and pieces is all stored in your head? Wish I could keep track of 02 changes, plug changes, air regulator cleans, coolant flushes, diff oils ect ect....
I personally think a modded car engine bay needs a GOOD visual inspection from above and below at least 3/4 times a year
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
