You actually couldn't be more wrong.
Longnose R200 in a HR31 is a 2-way mech locker, just very loose.
Few places and shims later, it's exactly the same as the Nismo item, or better if you customise it up a bit.
WTF... Are you reading the same post mate? or even the next line after the one you have quoted above?
"Viscous LSDs are not the real deal and even when new do not provide the response or locking capabilities of a mechanical LSD, after 100k+km's and a few laps of Sandown the stocker is 100% useless!"
No doubt the R31 diff is a doozy... but the R33 viscous LSD is a POS!
Edited by Checkbuzz
  • 8 months later...
2 way - locked under deaccell
1.5 way - partially locked under deaccel
So 2-way & having the rear wheels turn equally going into a corner with it locked up generally will induce understeer.
Once you get over that, it will snap/insta oversteer
How do you deal with the tendency to plow on in corner entry then - I'm referring to driving style - you just got to chuck it about more?
If you aren't drifting etc, IMO 1.5
2 way is fun if you know how to use em, but very demanding.
So you're saying that?
1.5 way = ghey
2.0 way = Charles Bronson?
:rofl2:
So what is the definitive truth re 2 way diffs? Some say it is suicide on a street car, others that is fine?:/
Is it more to do with how much lock you set it for?
I wanted a 1.5 way but ATM only 1 or 2 ways are going 2nd hand where I live.
Ok so i know sweet F A about diffs and dont profess to but my car has a kaaz 2 way and its rough as guts at low speed cornering on nice smooth concrete it chirps turning & the whole car shudders it is quite unfriendly for a daily drive. I personally havent noticed any difference in how it affects the handling though i must admit in the wet it does feel seriously slippery but i boiled that down to lotsa hp lol! BUT with 386hp on the tar my car doesnt do a great deal of wheel spinning
Never get why ppl complain about 2ways shimmed welded diffs for street i drove on weldy with 300 kw on the street for over a year and no problem if you drive properly its fine besides being abit noiser theres not much difference for everyday.
The Kaaz LSDs are noisey as fark during low speed cornering and put alot of stress on the rear subframe etc.
Some guys claim to quieten them down with LSD friction modifier but that only detracts from the performance of the LSD and is IMO ghey...
Kaaz LSDs are "off road" products designed for racing not daily driving it's as simple as that.
After I did mine I also replaced the diff mounting bushes and installed alloy lock collars on the rear subframe instead of poly pineapples - a vast improvement in rear end shuddering, axle tramp and subframe movement!
I can assure you that if you went back to a standard diff you would notice the difference - bigtime with 386HP!
My Kaaz LSD improved my lap times by over 1 sec @ Sandown simply because I could get more power to the ground earlier on corner exit and therefore reach higher speeds on the straight etc. It is also much easier to control the car in a power over-steer (i.e. drift) situations and in general.
The best thing you can do for a KAAZ is to run an 85w140 or similar LS oil. The 80w90 that they come with is just a run in oil and way too thin, creates heaps of noise when the oil warms up a bit.
Also, when going around corners at low speed (daily driving etc.), you can either hold the clutch in so it just coasts around the corner silently, or with clutch out give it plenty of throttle so that the tyres start chirping instead of the diff chattering. It's slipping the clutch around a low speed corner that causes the most chatter because you are power on / power off.
Is it the A-LSD that you are referring to ?
still running one with a lot of track work and 600+rwhp fine ?
I dunno dude... Do you see the letters "A-LSD" anywhere in any of my posts???
You can probably work out the answer for yourself from here... :blink:
P.S. You should be up for TROLL of the year with this! Nice work!
both me and a mate have OS giken 2 ways in our cars...
his.. unknown how long its been in, or when the oil was last changed..
i ordered my diff from otomoto in sydney, had to be shipped out from japan,
i am using the genuine oil... 80/250w grade oil , seriously thick!!
my mates one... chatters and makes noise like crazy.. mine is still quiet!
it has started to get a bit noiser now, but that could also be put down to the fact i just added solid metal subframe bushes and diff bushes.
getting use to the diff is easy... first time i drove it after fitting it ,was at a track day at wakefield.. just had to adjust the way i drive.. on the street i dont notice any real difference, coming out of round abouts is a bit more fun under acceleration as it feels alot better.
each to their own..
    • From my bolts, standard M8 with 1.25mm thread pitch (M8x1.25mm).    Length is 19mm under the head and has a captive 18mm OD flat washer.   20mm length from a bolt shop is what you'll be able to get.   Make sure they're zinc plated.    If you're concerned about strength, grade 8.8 will be more than enough. Original PN is 01121-04971.  Now discontinued according to Amayama but that's because it's one of the parts that's been captured by the Heritage program, which explains the ridiculous price.   New PN is 01121-RHR20: https://nismodirect.com/nismo-heritage-bolt-pin-hinge-hood-bnr32-nissan-skyline-gt-r-01121-rhr20-01121-04971/ About AUD33 converted from Yen in the above link but that's just one example. Interesting that the hinge-to-body bolts are still available non-heritage.....PN 08116-8161G around $2 each (amayama).    Same thread but 16mm long.
    • Well, if that filter was impeding fluid flow, then it could have similar effects to faulty solenoids. The TCU will register a fault when it does something (ie, changes the state of a solenoid) and does not detect the required result. If there are other causes that can make the same lack of result, then they will be indistinguishable to the expected cause for which the TCU has a code.
    • Yellowjackets, red ones, blue ones (other than Splitfire) have all been demonstrated to be unreliable on turbo engines. That unreliability can be anything from outright failure (ie, 4 out of a set of 6 working out of the box) to just not being strong enough for the task, on a boosted engine. Not enough of us care about NA engines to know whether that unreliability is an issue for the undemanding needs of an NA RB20. I should think though that the DIS-008 should fit the 20. There's not really any reason for the head/coil mounting area to be any different on those 2 Neos. I wouldn't be buying Splitfires, or any other old tech coilpack, for a car in this day and age though. I would buy modern pencil coils and do what needs to be done to adapt them to the loom. That's relatively trivial these days, with numerous kits for fitting R35, or Audi, or Yaris/Corolla coils.
    • Keen to see how much work is needed to get an abandoned Skyline going. My R32 has been sitting idle for three years or so but finally got some time to get it going again. (Also lurking SAU and trying to hit 10 posts so I can start my own intro thread with pics)
    • Hi. Which coilpacks can i use in my engine? I looked at the Splitfire but the closest "match" i found was SP-DIS-008 but even that they do not show RB20DE NEO so iam not 100% sure. Or maybe different one which will 100% work? I saw many on ebay but they are some cheap "strange" ones. What about Yellow Jackets? Many thanks 🙂
