mines triple flow cam cover baffle plates for rb 26 motor $275 BRAND NEW
stop blow by in the head, reduces the need for a catch can
brand new http://www.mines-wave.com/english/CATALOG/...AFFLE_PLATE.htm
"In case of the Nissan RB26 engine, the engine oil sent to the cylinder head remains inside the head without moving to the engine block due to its construction structure. Such oil remained inside the cylinder head will be discharged out together with the blow by gas since the oil will change its location according to the vehicle acceleration/slow-down & cornering. The Triple Flow Cam Cover Baffle Plate from Mine's has 3-layer structure, always maintains the gas passage. In addition, the gas/oil separator slows down the blow by gas flow and reduces the quantity of the discharged oil."
accidently ordered 2 pairs
$275
can meet in town weekdays for pickup
posted here, if any interest before posting in SAU classifieds
PM if interested
regards Jason
Greddy Turbo Timer with r32 harness - pretty much brand new $120
3 Drift Gauges (boost, water temp, oil pressure) $40 each
K&N pod filter - $20
how big are the boost gauges?
52mm or 60mm?
boost gauge is that in psi or bar?
Do you have the sandwhich plate for it?
PM me please
FOR SALE:
1992 Kawasaki ZXR750
Good condition, runs great
Has rebuilt gearbox and rebuilt carbs
Quick sale ... bargain $2000
Road registered or good for track bike
2003 GSXR600 Race/Track Bike
This has been my race bike for over a year. Selling due to downgrading to 250cc grade.
23,000kms engine. Engine is A1
2 sets of race glass
Tyre warmers and race stands
Full Leo Vince race system, Power Commander IIIr piggy back ecu
Showa USD fork conversion
Frame has been worked on and approved by Adrill Engineering
Raced for 3/4 of one season before I broke my shoulder. Only track days since.
Bargain $5,000 ono
Now the biggie! ...
2004 MV Agusta Brutale F4
Italian style and engineering with a 4cyl engine designed and built by Ferrari (hence the "F4")
Pure porn with carbon fibre parts (over $2,000), Ohlins adjustable shock ($2K)
Bike retails for $23K new
Fully rebuilt and customised with under 2K on the clock
$18,000 ... no dreamers ... no test rides.
PM for more info and pics
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
